2000 Impala, Autopage RST2050KE
diabloed
Copper - Posts: 133
Posted: September 21, 2002 at 11:29 PM / IP Logged
I am getting ready to install an Autopage RST2050KE remote start & keyless entry setup on a 2000 Chevy Impala. My question is about the Passlock? will i be able to install resistors on it ( like i did on my 99 GMC Yukon) or is it required to use like the dei part? If so which wires do i need to test?
Platinum - Posts: 12,488
Posted: September 22, 2002 at 8:33 AM / IP Logged
The 2000 Impala has a Passlock II system installed. You will need to follow these instructions to find the resistance of the passlock code:
1. Remove the top and bottom halves of the steering column shroud.
2. Locate the small three-wire harnesses (with RED / White, ORANGE / Black and Yellow wires) that
come off of the ignition key.
3. Cut the <>Yellow <>wire in half and bare back the <>ORANGE / Black <>wire.
4. Attach the (-) negative side of your meter to the Black wire where it was bared back. Next,
attach the positive (+) side of your meter to the cut yellow peice of wire that runs to the
Ignition Lock Cylinder. Set the meter to read at most 20,000 (20k) ohms of resistance..
5. With the ignition key in and turned to the <>"ON" <>or <>"Run" <>position put the vehicle into
REVERSE<>.
6. Turn the key to the <>"Start" <>position and release it to the <>"Run" <>and measure the resistance
between the key side of the <>Yellow <>wire and the <>ORANGE / Black <>wire.
7. When you have correctly identified the correct resistance obtain a resistance of the same
value.
Note: If you cannot obtain a resistance value, reconnect the Yellow wire and start the
vehicle with the key. Allow the ignition lights to normalize. Shut the vehicle off, separate
the Yellow wire and follow steps 4 – 7 again.
Note that the Yellow
wire for the Passlock is a similar gauge wire to the Starter wire. Don’t confuse these.
You must acquire a resistor value within 5% of the value of the resistor in the key.
diabloed
Copper - Posts: 133
Posted: September 22, 2002 at 9:55 AM / IP Logged
thanks alot velocity when it comes to this business you seem to be a great guy. and i'll tell you that's hard to come by.
Posted: September 22, 2002 at 9:08 PM / IP Logged
Hey thanks for the praise and I hope you finish your installation of the remote starter on the vehicle. If you need more help you know where to come.
Sound Pressure
Silver - Posts: 711
Posted: September 23, 2002 at 12:23 AM / IP Logged
Hey,
I have to agree with diabloed, Jeff has pulled me out of some though jams with some alarm installs. It is hard to come by people as nice and with the know how as Jeff and many others here at The 12 Volt.2000 Impala, Autopage RST2050KE -- posted image.
Sound Pressure
Posted: September 23, 2002 at 7:49 AM / IP Logged
2000 Impala, Autopage RST2050KE -- posted image. You guys make me feel like a star
