Resistance locks resistor placement?
BoominRolla
Copper - Posts: 198
Posted: September 10, 2004 at 8:12 PM / IP Logged
does it matter if I place the resistor on the lock/unlock wire itself or should I place it at the ground screw if using a relay?... I seem to get stumped once and awhile with certain vehicles... some work first time everytime and some are a lil more of a pain...  Just wondering if anyone else has run into this and found out the best way it worked for them...
auex
Platinum - Posts: 5,041
Posted: September 10, 2004 at 8:32 PM / IP Logged
Yes, it matters. You put the appropriate resistor on lock and unlock wire. If you put the resistor at the ground then both lock and unlock will have that resistance.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
zargon
Copper - Posts: 186
Posted: September 11, 2004 at 11:14 AM / IP Logged
you put the resistors on the lock and unlock out put wires coming from the relays, the only time i seem to be puting the resistor before the relay is on chrysler vans.
zargon ruler of estranorth
kgerry
Platinum - Posts: 3,455
Posted: September 11, 2004 at 11:15 AM / IP Logged
why would you put the resistor before the relays on these vehicles???
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
zargon
Copper - Posts: 186
Posted: September 11, 2004 at 11:16 AM / IP Logged
for that last post above i forgot to say for the parking light flash, thanks
BoominRolla
Copper - Posts: 198
Posted: September 11, 2004 at 3:51 PM / IP Logged
ok thanks!!!!
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
