Want To Add Power Locks Without An Alarm
newinstaller
Copper - Posts: 160
Posted: September 16, 2004 at 11:51 PM / IP Logged
Hi,
I want to do if a car does not have an alarm or wants an alarm can door lock actuators still be added just by using a switch?
How would you wire up the relay?
xtremeaudio
Copper - Posts: 174
Posted: September 17, 2004 at 2:26 AM / IP Logged
 hook up with out alarm you will need 2 relay one for lock and one for unlock
86 & 87 go to 12v(+) 87a go to (-) 85 go to swith and 30 go to lock or unlock motor
sparkie
Platinum - Posts: 2,061
Posted: September 17, 2004 at 4:09 PM / IP Logged
There are power door lock kits that are designed for this. They use 5 wire actuators for the front doors. When they are activated by moving the door lock lever on the inside of the door or by turning the key in the door key cylinder on the outside of the door, it causes the other door or doors to move as well. There are 2 and 4 door kits availabe. I use the system from Audiovox and it works well. They have triggers into the main module to remotely activate the door locks with an alarm if you upgrade the vehicle later.
sparky
Monday, December 22, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
