04 F250 Super Duty Diesal Tach
rschoener
Posted: September 21, 2004 at 9:20 AM / IP Logged
I am installing a Crime Stopper CS-2016FM Alarm/Remote Start/Turbo Timer into a 4 F250 Super Duty Diesal Tach. I have been though many tech sheets and I cannot find a Tach source.
There is a 5 wire loose bundle with a green white above the E-Brake release. (Mesure with meter and tried with unit. No a/c voltage. I also tested the other wires in that bundle.)
White pink from fire wall in main harness. (No such wire)
White Pink at ECM next to battery in engine bay. (Voltage just increses from 0 to about 7 volts it does not pulse like a normal tach. It will hold a voltage not switch.) I did try this and the truck will start and run for about 30 sec to a minute then the unit shuts down and goes full alarm.
White Pink behind Gauge cluster. (No such wire and i test all others for a tach source. non found.)
Tachless does not work consistantly at all. (Key off battery voltage 13.30vdc engine running voltage 14.40vdc. not a big change)
I must be missing something any help would be appriciated. Thanks
Randy
mo12v
Posted: September 21, 2004 at 9:27 AM / IP Logged
This is what I have:
On 7.3L Diesel Vehicles-The Tach Wire Is GREEN In A 42 Pin Plug Under The Clamp On The Engine Side Of The Air Intake Duct. On 6.0 Turbo Diesel Vehicles-The Tach Wire Is ORANGE In A BLACK 46 Pin Conn At The PCM Located On Driver Fender Wall.(Pin 43 Bottom Row Of Middle Conn) Glow Plug Wire:7.3L Diesel- WHITE/ LT GREEN (-) At 42 Pin Conn. Located On The Driver Rear Of Eng. Under Intake. 6.0L Diesel- VIOLET/ORANGE At PCM Located On Driver Fender Well In Engine Compartment.
MO
rschoener
Posted: September 21, 2004 at 9:48 AM / IP Logged
Thanks for the quick response. I will update after i try it out...
Thanks again.
Randy
dfiddy
Copper - Posts: 162
Posted: September 21, 2004 at 11:25 PM / IP Logged
I've found tach inside around the e-brake. Green I believe or GREEN/ something ;comes to a dead end inside. Directechs says this is an okay source for tach.
the1alchemist
Copper - Posts: 65
Posted: September 23, 2004 at 9:07 PM / IP Logged
The CS2016 fm has a tach finder mode..i forget exactly how,but it is in the manual,and the budle of wires has one in it.you wont hurt the alarm...the papers are at work,if you pm me the techweb ser# i can e-mail you the digrams for both the alarm,and the vehicle..but if the tach is it,i have done 3-4 02-03 diesels.. I never keep up with whats what,if i see the same thing under a dash,i know what to do..
anyway..techweb ser#(like 16-20 digs?just typed one in today..it's long..do it 2*)
'Stereo' Mike
The Audio CARtist,LLC
9600 Balt. Ave.
College Park,MD 20740
301-474-6260
the1alchemist
Copper - Posts: 65
Posted: September 23, 2004 at 9:09 PM / IP Logged
I dont know what i would do without my snapon vantage!Tach wires are KNOWN to be perfect(or not) in SECONDS!!!
'Stereo' Mike
9600 Balt. Ave.
301-474-6260
the1alchemist
Copper - Posts: 65
Posted: September 23, 2004 at 9:10 PM / IP Logged
woops!thought it didnt make it the first time!
'Stereo' Mike
9600 Balt. Ave.
301-474-6260
