backup syren
daylapino
Posted: April 19, 2002 at 8:32 PM / IP Logged
hi, ì have a new backup syren to install but i am not sure how to install the trigger wires on it . there is a red wire for the jus ablack for the ground but the positive and negative triggers are unknown. any info would be appreciated
mobiletoys2002
Gold - Posts: 1,050
Posted: April 20, 2002 at 6:07 PM / IP Logged
ok i dont get your question totally but here goes you have  saecond siren u want conected to your original ?  so u will have two off of one alarm well the red of the siren is the positive triger input from the alarm usually alarms use brown as thier siren out put and the black will go to ground ie(the chassis of the car) now if you do want two alarms going at once u should connect a relay as follows to assure you will not burn that alarms siren out put follow carefully  pin 86 of the relay will go to the alarm brains positive siren output now 85 will go to ground now 87 will go to a 12 volt source fused with a 5 amp fuse near the battery now pin 30 of the relay will go to all ur red siren wires u have and all the black siren wires wiill go to the chassis ground its easy any thing else ask ill help u good luk
hot_shot_guy123
Copper - Posts: 114
Posted: April 20, 2002 at 10:27 PM / IP Logged
so the siren you're hooking up is a batt-back-up siren right?  For your siren hook up the red to constant 12v fused, black to ground.  For the other 2 wires you have to know if your alarm has a positive or negative trigger output.  Hook up the relay exactly how mobiletoys2002 said.  I tried avoiding a relay in a multiple siren hook-up before and well, you learn from your mistakes.
hot_shot_guy123
Moderator - Posts: 12,488
Posted: April 21, 2002 at 11:09 AM / IP Logged
Go to these last posts for information concerning the back-up siren: https://www.the12volt.com/installbay/display_topic_threads.asp?ForumID=3&TopicID=181&PagePosition=3
Sunday, November 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
