Clifford 550 Sensors
plunkett
Posted: September 23, 2004 at 5:43 AM / IP Logged
Hey,
Ive just fitted a clifford 550, ive wired in both sensor (Proxy & Tilt)  but i cant seem to manage both to work together, i can only 1 or the other, not both together,
Any Ideas
James
hagmanti
Silver - Posts: 304
Posted: September 23, 2004 at 7:35 AM / IP Logged
Any Ideas
Just the obvious-- have you diode isolated the outputs of both sensors? (Diode stripes should both face sensors).
Have you grounded both sensors to a fairly strong ground? I would take the ground-when-armed output to a relay, and then both proxy and tilt to chassis ground through that relay. (85-- 12V, 86-- ground-when-armed, 30-- chassis ground, 87-- to both sensors' grounds).
I'm not familiar w/ the 550, but is it possible to put them both on different zones? If that is possible, try doing that.
Hope this helps,
Sunday, April 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
