power windows kit
antonio1279
Posted: September 23, 2004 at 1:17 PM / IP Logged
anybody know how to install or have diagrams for a 3 switch power windows kit from spal. i have a toyota echo 2000 manual the wiring is throwing me off
NowYaKnow
Gold - Posts: 1,217
Posted: September 23, 2004 at 7:24 PM / IP Logged
I'm going off of memory here and a lot of these kits aren't all the same wire colors, but see if this helps. You should have a thick red wire which goes to ignition power, a thick black or brown that goes to ground, and a gray wire that goes to the + parking lights in the car. The rest of the connections all take place between your switches and your motors. At the driver side switch the RED / blue is your parking lights, the red goes is power, the 2 PURPLE / black wires go to the driver window motor wires, and the 2 browns go to the grounds. The other wires run over to the passenger door and the colors are similar. Let me know if any of this coincides with what wires you have..
Mike
