diode on starter interupt
brucejf69
Member - Posts: 29
Posted: October 01, 2004 at 1:46 AM / IP Logged
I just read this thing that said you should have a diode on a relay that is used for a starter killer.  Is this true? If so does anyone have a diagram for this? Thanks
mo12v
Posted: October 01, 2004 at 8:34 AM / IP Logged
To the Top Left is a List of Basic's
Try:
https://www.the12volt.com/relays/page2.asp
MO
brucejf69
Member - Posts: 29
Posted: October 01, 2004 at 12:40 PM / IP Logged
So that is just for a passive starter killer?  If it is hooked up to an alarm it doesn't need a diode?
brucejf69
Member - Posts: 29
Posted: October 01, 2004 at 5:40 PM / IP Logged
Wow...am I ever blind...never saw that little sucker in the diagram before. Someone should label that.  Will a 1n4001 diode work for that? Thanks
Teken
Gold - Posts: 1,492
Posted: October 01, 2004 at 6:00 PM / IP Logged
Yes . . .
Saturday, February 21, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
