2002 grand marquis
tek1000
Member - Posts: 13
Posted: October 12, 2004 at 9:18 PM / IP Logged
hey any one know where the location of the factory keyless entry mod and the colors for the lock and unlock wires at the mod on a 2002 mercury grand marquis thanks for any help.
mo12v
Posted: October 12, 2004 at 9:31 PM / IP Logged
U don't have to go to RKE to hook up door locks
Here is what I have:
Power LockPINK / YELLOWEITHER KICK
Power UnlockPINK/L GREENPANEL **
** Without OEM Keyless Entr    Reversal Rest At Ground Door Lock
   With OEM Keyless Entry   Positive Pulse Door Lock Diagram.
RKE ModuleLOCATED IN DRIVER DOOR
Motor LockPINK/BLACK16 PIN CONN. NEXT TO DR. KICK PANEL *
Motor UnlockPINK/ORANGEDRIVER KICK PANEL *
Drv Door UnlockRED / ORANGEAT OEM KELTLESS MODULE **
OEM RelaysBUILT INTO KEYLESS MODULE
* All Door Lock Wires Can Also Be Accessed At OEM Keyless Module. Circuit Type - Reversal Rest At Ground. ** Driver Unlock Is PINK/ORANGE With Out Keyless Entry
MO
tek1000
Member - Posts: 13
Posted: October 12, 2004 at 11:01 PM / IP Logged
 I am trying to install a valet 561t remote start using the factory remotes off the lock wire from the keyless entry is this possible?
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
