2004 trailblazer ext
sahall32
Member - Posts: 11
Posted: October 14, 2004 at 7:29 PM / IP Logged
I'm installing a alarm/rs in a 04 trailblazer and the wires listed on the several wire list that I have are totally different. parking lights on the list are showing +brown in the drivers kick panel but I found them to be on a -grey/black and the dome light shows +grey/black but I found that it is -blue/white , both parking and dome light wires coming from switch. does anyone show what I found to be correct? Do I need to keep looking some more?
also I want to use a gmdaa module in this truck will that work ok?
Thanks,
Steve
snguyen
Silver - Posts: 281
Posted: October 14, 2004 at 7:57 PM / IP Logged
Chevrolet
Trailblazer
2002-2004
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
YELLOW
IGNITION SWITCH HARNESS *
Ignition  #1:
PINK
Ignition #2:
WHITE
Ignition  #3:
BROWN
Accessory:
ORANGE
Brake  Light:
WHITE
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
WHITE
IN BLUE PLUG AT THE ECM ON DRIVER'S SIDE OF MOTOR
Parking Lights:
BROWN (+)
DRIVER'S KICK PANEL
Headlights:
OEM Alarm  Disarm:
LT. GREEN (-)
INSIDE OF DRIVER'S DOOR AT MODULE
OEM Alarm  Arm:
Diesel  Glow Plug:
N/A
Clutch  Bypass Wire:
N/A
Notes:
 * This Vehicle Is Equipped With GM's PASSLOCK II Anti-Theft System; Use Universal Alarm Bypass Module or Vehicle Specific Bypass DTI #23545 ****All DesignTech remote starters except the 2xx22 have an ignition 3 output - it is the WHITE/ black in the 'control harness.' This wire will be used to control the bypass module, if needed. This wire will require a relay for the Brown (ACC)wire.
Chevrolet
Trailblazer
2002-2004
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED
Starter  Kill:
YELLOW
Ignition  +12 Volts:
PINK
Dome  Lights/Superv:
GRAY/BLACK (+)
UNDERNEATH DASH AT COURTESY LAMP
OEM Horn:
BLACK / YELLOW (-)
STEERING COLUMN HARNESS
Power  Lock:
SEE NOTE BELOW ***
CAUTION - DATABUS SYSTEM
Power  Unlock:
SEE NOTE BELOW ***
INTERFACE MODULE RECOMMENDED!
Trunk  Release:
N/A
Alarm  Input Wire:
GRAY/BLACK (+)
Notes:
*This vehicle uses an extremely complex lock/unlock circuit. To Lock/Unlock, we recommend use of the 23561 Door Lock Interface module, available through DesignTechs sales department at 800-337-4468 . Alternatively, you can wire inside each door for reverse polarity door locks. The 23561 module is easier to install, less expensive, and requires less wiring than the reverse polarity/relay method. Motor Wires, should you choose the reverse polarity method, are Gray for Lock and Tan for unlock. SOME of these vehicles have a switch on the right rear panel which can lock/unlock all doors as a positive trigger system. If so equipped, the wires are Lt Blue for lock and White for Unlock. Connection of the locks without the module is not supported.
NowYaKnow
Gold - Posts: 1,217
Posted: October 14, 2004 at 10:03 PM / IP Logged
On the trailblazers you can use gray/black (-) @ the switch OR brown (+) for the park lights. Also the domelight wire is gray/black (+) @ the domelight. Just because the diagrams may list one wire doesn't mean there aren't alternatives.
Mike
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
