Alarm (-) output to 3 relays
sm951
Member - Posts: 25
Posted: October 20, 2004 at 9:51 AM / IP Logged
Hi,
I'm thinking about using the single continuous negative output that my RKE emits, when armed, as the ground for the coils of 2 or 3 separate relays.  Would I need any diodes or anything else across these 2 or 3 wires?
Thanks in advance,
sm
ampere
Member - Posts: 40
Posted: October 20, 2004 at 10:23 AM / IP Logged
As long as your grounds for your relays are not supplying a load (ie just triggering the relays) you should be fine.
