compustar 2005 dodge grand caravan
radeon200
Posted: October 20, 2004 at 10:47 AM / IP Logged
I have a compustar 2wss-ass need help on power lock and power unlock install.  Does anyone have any information with picture or diagram for installation that would help me alot thank.
Platinum - Posts: 12,488
Posted: October 20, 2004 at 12:01 PM / IP Logged
http://www.velocitymotorsport.com/images/install_notes/144.jpg
Lock is negative trigger thru a 5.3K ohm resistor. Unlock is negative trigger thru a 2.0K ohm resistor. MUST use relays.
The BCM (Body Control Module) is in the driver kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs.
radeon200
Posted: October 20, 2004 at 12:23 PM / IP Logged
also do you have any information with picture on the parking lights (-) that also require relay?
Thanks.
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
