2005 Dodge Grand Caravan Remote Start/Alarm Wiring
radeon200
Posted: October 21, 2004 at 9:20 PM / IP Logged
Iam trying to install a remote start/alarm on a 2005 Dodge Grand Caravan. I need to get the wiring diagram. Could somebody provide some help locating the diagram as well as providing any tips or information.  Thank you.
JWorm
Platinum - Posts: 2,208
Posted: October 21, 2004 at 9:51 PM / IP Logged
Same car
https://www.the12volt.com/installbay/forum_posts.asp?tid=41335&PN=1
eurotek
Copper - Posts: 58
Posted: December 21, 2004 at 10:59 PM / IP Logged
JWORM, you are wrong, this vehicle is different
for one, the starter is a negative
KarTuneMan
Platinum - Posts: 7,056
Posted: December 21, 2004 at 11:07 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - DODGE / CARAVAN / 2005 / Remote Start
[PRINT THIS PAGE]
12voltslt. blue/red (10A) + ignition harness
Starteryellow + ignition harness
Second StarterPURPLE / brown - ignition harness
Notes: The second starter wire is negative trigger thru a 180 ohm resistor. MUST use a relay. Refer to DirectFax document 1083 for wiring information.
Ignitionpink/white + ignition harness
Second IgnitionN/A
Third IgnitionN/A
Accessorynot required for remote start
Second AccessoryN/A
KeysenseN/A
Power LockPURPLE / dk. green - BCM, white plug, pin 21
Notes: Lock is negative trigger thru a 5.3K ohm resistor. Unlock is negative trigger thru a 2.0K ohm resistor. MUST use relays.
The BCM (Body Control Module) is in the driver kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs.
Power Unlocksame as power lock wire
Lock Motortan/white 5wiBCM, green plug, pin 10
Notes: The BCM (Body Control Module) is in the driver kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs.
Unlock Motortan/lt. green 5wiBCM, green plug, pin 28
Parking Lights+WHITE/ brn (L), WHITE/ org (R) + driver kick, harness to rear
Parking Lights-WHITE/ brown - switch or BCM, gray plug, pin 21
Notes: The parking lights are negative trigger thru a 2.1K ohm resistor. There is a rest resistance on the wire, so MUST use a relay to isolate away from the switch. See DirectFax document 1082 for wiring information.
HazardsWHITE/ dk. blue - switch or BCM, gray plug, pin 31
Turn Signal(L)wht/lt blu (F), wht/dk grn (R) + BCM, green plug, pins 1, 2
Turn Signal(R)WHITE/ tan (F), WHITE/ brown (R) + BCM, green plug, pins 3, 4
Reverse LightWHITE/ lt. green + BCM, green plug, pin 9
Door Triggersee notes - BCM, white plug
Notes: The driver door trigger is purple in pin 6, the passenger door is PURPLE / white in pin 7, the left sliding door is PURPLE / gray in pin 8, and the right sliding door is purple / YELLOW in pin 5. Use all four wires and diode isolate each. Also have to diode isolate from the BCM. Refer to DirectFax document 1076 for wiring information.
Dome Supervisionyellow/brown or yellow/white + BCM, white plug, pin 33
Trunk/Hatch PinPURPLE / orange - BCM, white plug, pin 29
Notes: A diode must be placed inline on this wire to avoid problems with the dome lights and parking lights.
Hood PinPURPLE / lt. blue (export model) - BCM, white plug, pin 30
Trunk/Hatch ReleasePURPLE / tan - BCM, green plug, pin 6
Notes: Hatch release is negative trigger thru a 1.69K ohm resistor. MUST use a relay.
Power Sliding DoorPURPLE / dk. blue - BCM, white plug, pin 1
Notes: Left power sliding door is negative trigger thru a 1.5K ohm resistor. Right power sliding door is negative trigger thru a 2.7K ohm resistor. MUST use relays.
Factory Alarm Armarms on lock with door open
Factory Alarm Disarmfactory remote only
Disarm No Unlockwith ignition and Sentry Key
TachometerNOT BROWN / white ac ign coil pack or any fuel injector
Wait to startN/A
Brake WireWHITE/ tan + brake pedal switch
Parking Brakedk. GREEN / WHITE - parking brake switch
Horn Triggerdk. GREEN/ purple - steering column
Memory Seat 1PURPLE / brown - BCM, green plug, pin 24
Notes: Memory seat 1 is negative trigger thru a 6.8K ohm resistor. Memory seat 2 is negative trigger thru a 2.1K ohm resistor. MUST use relays.
Memory Seat 2same as memory seat 1 wire -
Memory Seat 3N/A -
2005 Dodge Grand Caravan Remote Start/Alarm Wiring -- posted image.
Immobilizer Bypass Module:Required: YesType: Sentry KeyPart #: 556U or 555U
Notes: Standard on SXT models. Optional on SE models.
KarTuneMan
Posted: December 21, 2004 at 11:10 PM / IP Logged
12volts
 lt. blue/red (10A)
 ignition harness
Starter yellow  +  ignition harness
Second Starter PURPLE / brown  -  ignition harness
Ignition pink/white  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory not required for remote start
Second Accessory N/A
Keysense N/A
Power Lock PURPLE / dk. green  -  BCM, white plug, pin 21
Power Unlock same as power lock wire
Lock Motor tan/white  5wi BCM, green plug, pin 10
Unlock Motor tan/lt. green  5wi BCM, green plug, pin 28
Parking Lights+ WHITE/ brn (L), WHITE/ org (R)  +  driver kick, harness to rear
Parking Lights- WHITE/ brown  -  switch or BCM, gray plug, pin 21
eurotek
Copper - Posts: 58
Posted: December 21, 2004 at 11:18 PM / IP Logged
what is the disarm defeat?
Tuesday, January 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
