Please help me with my camry 99
vietboi614
Member - Posts: 6
Posted: October 02, 2002 at 8:15 PM / IP Logged
I having a camry 99 already installed with crimestopper 2006 FM pager.  I need to install the roll up window molude for 2 windows. Can someone please help me with the wiring diagram? Please provide me the wiring diagram for LEFT MOTOR, LEFT SWITCH, 500mA ACTIVIATION, RIGHT MOTOR, RIGHT SWITCH, also please let me know where are those wire locate.  Please show me how to program it with my remote control. Will it still work if I install the power trunk too?
Another question is how to install the power trunk for my camry 99.  Since when I bought my camry they didn't give me the remote controls(The 4 buttons I guess, but not sure). They told me that my car has the power trunk already so I really don't know I can install it or not.  Please help me how to hook up with the trunk. Please give me the wiring diagram to0:)
PLEASE HELP ME!  THANKS EVERYONE!
P.S.  ANYONE NEED THE WIRING DIAGRAM FOR 85-01 CAMRY AND 99-02 SOLORA PLEASE ASK ME I HAVE IT.
steven
LudeBoi
Copper - Posts: 81
vietboi614
Member - Posts: 6
Posted: October 02, 2002 at 9:29 PM / IP Logged
Thanks LudeBoi!  Can you tell me what is 500mA activition mean?
steven
LudeBoi
Copper - Posts: 81
Posted: October 02, 2002 at 11:44 PM / IP Logged
wire it to something that will signal it to do its job.
LudeBoi
Copper - Posts: 81
Posted: October 02, 2002 at 11:45 PM / IP Logged
wire it to something that will tell it to do its job, ex. an Aux output from your alarm.
vietboi614
Member - Posts: 6
Posted: October 03, 2002 at 6:07 AM / IP Logged
Thanks LudeBoi! Your information helped me a lot.
There are 8 wires for my window molude, and if the orange go to the aux output then where can I connect the pink wire?????
PINK= TO ACCESSORY ITEM
GREEN=LEFT MOTOR
WHITE+LEFT SWITCH
ORANGE=500 mA ACTIVATION
BLACK=GROUND
RED= +12 VOLTS
BLUE=RIGHT MOTOR
BROWN=RIGHT SWITCH
How can I tell that my trunk is electronic trunk.  Do I need a electronic trunk to connect it with the alarm to open it with the remote?
Please help me everyone!  Thanks!
LudeBoi
Copper - Posts: 81
Posted: October 03, 2002 at 7:33 PM / IP Logged
i just recently installed one, i located the left and rite window, cut them...now you will have a total of 4 wires, connect the correct left/right, switch/motor, connections, connct 12 volt constant, ground, and activation, bamm ur done
vietboi614
Member - Posts: 6
Posted: October 06, 2002 at 1:51 PM / IP Logged
I connected all the wires like you said and I still have pink wire that I really don't know where to connect it. The unit seem not to work if I don't connect the pink wire.
Please help!
steven
LudeBoi
Copper - Posts: 81
Posted: October 06, 2002 at 7:09 PM / IP Logged
Please help me with my camry 99 -- posted image.
did you follow this? where did you connect the pink wire?, i didn't even have to use it at all.
redsupra
Posted: October 07, 2002 at 6:17 PM / IP Logged
HI there!
I have 1993 toyota carmy and I would like to ask
if anybody know how to install the remote stater??
please send me an wiring diagram of that!
thank,
Saturday, August 9, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
