wiring diagram
trust
Posted: October 03, 2002 at 5:41 AM / IP Logged
Hey people,
I am about to do a alarm install and i was hoping some clever people could help me with some queries relating to the wiring diagram supplied with the alarm. Click here http://www.users.bigpond.net.au/stuffthatrock/stuff/diagram.jpg to see the diagram.
There are three question marks that i am confused about.
1. Why would there be two ignition wires of different lengths (one is about 10cm and the other about 2m) ?
2.what is the difference between "IGNITION ON" and "IGNITION POWER" ??
3. Why do I need a wire to the oil light or high tension coil ???
4. Do i only have to use the door swich wire that is applicable to my car? What do I do with the other wire?
Some extra info : install car is a nissan 1990 240 sx alarm is an "equator" (noname) with remote start.
Thanks everyone and sorry for the super long post!!
Moderator - Posts: 12,488
Posted: October 03, 2002 at 8:49 PM / IP Logged
  • Most systems that have 2 ignitions wires have one for primary and the other for 2 nd ignition. The diagram doesn't distinguish between the two for some reason.
  • From looking at the diagram the " IGNITION ON " wire would be yor constant power wire and the IGNITION POWER wire would be your switched ignition ( primary )
  • I have never seen this connection before ? Maybe it's called something else in other models.
  • Yes, your car uses the BLUE (-) trigger door wire
5.  What do I do with the other wire?
  • No, tape the wire up or disconnect from the harness.
trust
Posted: October 04, 2002 at 4:56 AM / IP Logged
Wow :) thanks for the great info Velocity.
I am going to do the install tomorrow and you have about solved the majority of my problems :)
Thanks again.
Posted: October 04, 2002 at 5:17 PM / IP Logged
no problemo
Tuesday, December 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
