Heated Seats
FairWeather
Member - Posts: 19
Posted: October 24, 2004 at 10:02 PM / IP Logged
Quick question
I want to tie my heated seats into the auxiliary output for my compustar remote. Anyone know if there is a way to catch the heated seats without having to open up the driver and passenger doors on a 2004 Chevy Tahoe? Also, this vehicle has 2 separate buttons (one for seat & back OR one for just your back) and the seat has 3 separate heating levels depending on the number of times you hit the button.
Tips and knowledge are appreciated. Thanks.
You can do it!
blackshuck
Member - Posts: 29
Posted: October 25, 2004 at 1:39 PM / IP Logged
I'm not sure, but I do know that taking off doorpanels is never really a big deal, and is probably your easiest bet on doing this right.
ampere
Member - Posts: 40
Posted: October 25, 2004 at 2:03 PM / IP Logged
You can use an AUX channel set to validity to accomplish this. Each time you press your button (or button combination) on your remote, it will increase your heat level.
kgerry
Platinum - Posts: 3,455
Posted: October 25, 2004 at 5:58 PM / IP Logged
if i'm not mistaken Trilogix makes a data model that allows for this on class II data.... or at least they show heated seats as an option
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Tuesday, November 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
