92 fullsize blazer Diagram
northballer
Copper - Posts: 57
Posted: October 26, 2004 at 2:15 PM / IP Logged
Can someone please give me the alarm diagram for this car thanks.
Roy dz
Member - Posts: 9
mo12v
Posted: October 26, 2004 at 2:32 PM / IP Logged
Constant 12 voltsRED AND REDIGNITION SWITCH HARN.(BOTH 1 CIRCUIT)
Ignition 12 voltsPINKIGNITION SWITCH HARNESS
StarterPURPLE AUTOMATIC TRANSYELLOW - MANUAL TRANSMISSION
Dome LightWHITE(-) PIN SWITCH OR AT COURTESY LIGHT
Trunk Pin SwitchWHITE(-) AT PIN SWITCH
Parking LampBROWN(+) AT HEADLIGHT SWITCH
Power LockLIGHT BLUEDRIVER KICK PANEL OR
Power UnlockBLACK/ WHITE OR BLK/REDBELOW DRIVER SPEAKER
Reversal Rest At Ground Door Locks
Accessories
Window UpD\ D BLUE P\ D BLUE/WHT @ MAIN SWITCH
Window DownR/ BROWN S/ TAN
Ign Key WarnLIGHT GREEN (-)STEERING COLUMN HARNESS OR CHIME MOD.
Trunk ReleaseBROWN(+) AT RELEASE SWITCH
OEM HornBLACK (-)STEERING COLUMN HARNESS OR AT RELAY
HeadlightsYELLOW (+)HEADLIGHT SWITCH OR BEAM SELECT SW.
OEM Alarm ArmN/A
OEM Alarm DisarmN/A
 Reversal Rest At Ground Power Window Circuit
Positive Pulse Trunk Release
Remote Start
Tach SignalWHITEAT DISTRIBUTOR *
Ignition #2ORANGEIGNITION SWITCH HARNESS (HEAT/AC)
Ignition #3N/A
AccessoryBROWNIGNITION SWITCH HARNESS (RADIO/WIPER)
Neutral SafetyORANGE / BLACK (-)AT SWITCH ON STEERING COLUMN
Brake LightWHITE (+)AT SWITCH ON BRAKE PEDAL BRACKET
Reverse LightLIGHT GREEN (+)AT SWITCH ON STEERING COLUMN
Rear Window Defrost
* Throttle Body Injection Engine.
MO
Tuesday, February 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
