2001 nissan maxima
Ohmz
Copper - Posts: 193
Posted: October 04, 2002 at 11:47 AM / IP Logged
I need to do a remote start on this vehicle. Can you supply me with diagram info and any special parts I need to do the remote start. I notice tha chip in the key.
My Personal Installer Note: Connectors are easy, neat, and professional. But do you know how to crimp properly?
brianh
Silver - Posts: 518
Posted: October 04, 2002 at 11:52 AM / IP Logged
Try www.bulldogsecurity.com they have a good tutorial on how to install a remote start and some good tips on wire connections.  Good Luck      Brian
kickyride
Copper - Posts: 100
Posted: October 04, 2002 at 4:36 PM / IP Logged
Bulldog does have a good basic tutorial but beware of their wiring diagrams. I have found some of there information to be a bit inaccurate. You'll need to make sure that you use a remote start that can easily be expanded to compensate for 3 ignition outputs and 2 starter outputs because the vehicle has a cold start wire which is essentially a second starter wire. You'll need an extra ignition key and something like Omega's PASS-4 module. Other than that, everything is pretty straight forward. I hope this helps.
Mike
Mike
Sales/Tech Support - KICKYRIDEoCOM mobile electronics
MECP 1st class-Security Specialist
Moderator - Posts: 12,488
Posted: October 04, 2002 at 4:50 PM / IP Logged
|              12V|green               |+  |ignition harness            |
|          STARTER|BLACK/ red or blk/wht|+  |ignition harness            |
|   SECOND STARTER|BLACK/ blue          |+  |ignition harness            |
|         IGNITION|BLACK/ red (smaller) |+  |ignition harness            |
|        ACCESSORY|RED / yellow          |+  |ignition harness            |
| SECOND ACCESSORY|WHITE/ blue          |+  |ignition harness            |
|       POWER LOCK|gray                |-  |pin 23 at SECU *1           |
|     POWER UNLOCK|BROWN / yel           |-  |pin 35 at SECU *1           |
|       LOCK MOTOR|purple              |   |pin 15 at SECU *1           |
|     UNLOCK MOTOR|WHITE/ black         |   |pin 13 at SECU *1           |
|    DISARM DEFEAT|GREEN/ YELLOW        |   |pin 14 at SECU *1           |
| PARKING LIGHTS +|RED / blue            |   |driver kick panel *2        |
| PARKING LIGHTS -|lt. blue            |   |headlight switch            |
|       HEADLIGHTS|pink                |-  |headlight relay *7          |
|     DOOR TRIGGER|*3                  |   |SECU *1                     |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|purple / YELLOW       |-  |pin 38 at SECU *1           |
|         HOOD PIN|yellow/red          |-  |pin 27 at SECU *1           |
|TRNK/HTCH RELEASE|blue                |*4 |pin 12 at SECU *1           |
|  FCTRY ALARM ARM|ORANGE / black        |-  |pin 41 at SECU *1           |
|FCTRY ALRM DISARM|ORANGE / blue         |-  |pin 30 at SECU *1           |
|       TACHOMETER|WHITE/ green         |   |instrument cluster *5       |
|      SPEED SENSE|pink/blue           |   |instrument cluster *6       |
|       BRAKE WIRE|RED / green           |+  |brake switch or drivers kick|
|     HORN TRIGGER|GREEN / WHITE         |-  |steering column             |
|           WIPERS|blue(L), blu/blk(H) |-  |steering column             |
|  LF WINDOW UP/DN|blue - green        |A  |drivers window switch       |
|  RF WINDOW UP/DN|RED / wht - RED / blk   |A  |drivers kick panel          |
|  LR WINDOW UP/DN|yellow - red        |A  |drivers kick panel          |
|  RR WINDOW UP/DN|grn/wht - green     |A  |drivers kick panel          |
| SUN RF OPN/CLOSE|not recommended     |   |                            |
|        RADIO 12V|yellow              |+  |at radio                    |
|     RADIO GROUND|                    |   |                            |
|     RADIO SWITCH|purple              |+  |at radio                    |
| RADIO ILLUMINATE|RED / white           |+  |at radio                    |
|    POWER ANTENNA|GREEN / WHITE         |+  |at radio                    |
|       LF SPEAKER|blu/wht - blu/yel   |   |at radio or speaker         |
|       RF SPEAKER|brown - brn/wht     |   |at radio or speaker         |
|       LR SPEAKER|lt. grn - blk/yel   |   |at radio or speaker         |
|       RR SPEAKER|blue - pink         |   |at radio or speaker         |
Notes:
NOTE:  This vehicle has an immobilizer system that needs to be bypassed during remote start operation.   *1 The SECU (Smart Entrance Control Unit) is located to the passengers side of the steering column.  *2 Can also find RED / green or RED / yellow at fuse box.  *3 Find lt. blue for the drivers door in pin 29, RED / blue for the passenger front door in pin 40, and RED / white for the rear doors in pin 28.  Use all 3 wires and diode isolate each.    *4 Requires a high-current ground for activation.  *5 Located on the rear of the instrument cluster in the white plug.  Do not start the car with the cluster unplugged.  Can also find the WHITE/ green at the ECM located in the front of the center console on the transmission hump. The wiring is easily reached by removing the panel just to the front of the center console on the passenger side. DO NOT UNPLUG THE ECM.  *6 Located on the rear of the instrument cluster in the 20 pin brown plug.  Do not start the car with the cluster unplugged.  Can also find the wire at the ECM.  *7 The headlight relay is in the relay box under the hood.
kickyride
Copper - Posts: 100
Posted: October 05, 2002 at 5:07 PM / IP Logged
There you go. DEI info is always reliable. That should give you a good idea of what you are up against.
Mike
Chris Luongo
Platinum - Posts: 3,746
Posted: October 08, 2002 at 9:02 PM / IP Logged
I'm often dissatisfied with DEI information, but their Nissan wiring charts are always spot-on.
I haven't done a remote start on a Maxima in some time, but I've done a few of the identical Infiniti....I35's I think they are.
The second-accessory wire operates the radio; it isn't necessary for remote start.  Who wants to have the radio wake up their neighbor when the car is remote started?
Instead of setting up a second starter relay, many installers simply tie the car's two starter wires together, connecting the remote starter's single output to both of them.  Even though it sounds bad, I've never heard of anyone having trouble using this method.
kickyride
Copper - Posts: 100
Posted: October 09, 2002 at 6:55 AM / IP Logged
You are right. I usually tie them together too. I'm guess I'm just trying to preach proper installer etiquette (if there is such a thing) :]
Mike
Ohmz
Copper - Posts: 193
Posted: October 09, 2002 at 12:26 PM / IP Logged
That's the way I did it, I tied both starter wires together. I've never had a problem doing this with other vehicles in the past. I used the DEI 555u module to bypass the immobilizer system. The car is very straight foward.
Wednesday, December 24, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
