rs anti theft bypass
hooyah
Posted: October 29, 2004 at 9:52 AM / IP Logged
I own a 97 monte carlo. any diagrams on how to bypass the anti theft sysem for remote start? cheap easy way of doing this?
thepencil
Gold - Posts: 1,526
Posted: October 29, 2004 at 10:06 AM / IP Logged
There is no easy or cheap way. Just the correct way is all that matters if you want to do it right.
You need to get yourself one of these. Bypass-Look down the list for your car.
Here is the wiring diagram for your car.
Be careful whose advice you buy, but be patient with those who supply it.rs anti theft bypass -- posted image.
jmr964
Copper - Posts: 70
Posted: October 29, 2004 at 10:15 AM / IP Logged
Are you talking about an actual factory alarm or wanting to bypass the resistor embedded in the key.  If you just want to bypass the resistor in the key, take the key and measure the resistance of the resistor and then all you need is a relay and a resistor of the same approximate value.
Jason
CementBrain
Copper - Posts: 61
Posted: October 29, 2004 at 10:40 AM / IP Logged
This is the wiring for a 97 Monte Carlo:
1995-97 Chevrolet Monte Carlo Security Information
Constant 12V+     Red      Ignition Switch Harness
Starter      Yellow      Ignition Switch Harness
Ignition      Pink      Ignition Switch Harness
Ignition 2      Brown      Ignition Switch Harness
Ignition 3      Purple      Ignition Switch Harness
Accessory      Orange      Ignition Switch Harness (Heat/AC)
Tach      White      Ignition Module
Brake Switch      White      Brake Switch
Trunk Release      Black (+)      Switch
Trunk Pin      RED / Black (-)      Light in Trunk
Parking Lights      Brown (+)      Light Switch
Head Lamp      Yellow (+)      Light Switch
Door Trigger      Dark Blue (-)      Driver's Kick Panel 20 Pin Connector
Door Lock      Light Blue      Driver's Kick Panel 20 Pin Connector
Door Unlock      White      Positive Trigger
Horn Wire      Black (-)      Steering Column
Windows Up      LF=Dark Blue, RF=Light Blue, LR=Dark Green, RR=Light Green
Windows Down      LF=Brown, RF=Tan, LR=Purple, RR=Purple
1995-97 Chevrolet Monte Carlo Cruise Information
Constant 12V+      Red      Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+      Pink      Ignition Switch Harness
Ground      Use Chassis      Near Cruise Control Module
Hot Side of Brake      Orange      Brake Switch
Cold Side of Brake      White      Brake Switch
VSS Lead      Dark Green      Passenger's Front Quarter PCM Position 28 or Position 13
Pulses Per Mile      4000 PPM
Notes: Vehicles with Manual Transmission require Clutch Switch. Some vehicles may require a speed signal generator and/or other parts/adapters not listed above. Rostra® Cruise module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
CementBrain
Thursday, April 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
