wiring diagram for 2004 Sport Trac
telesplicer
Posted: November 06, 2004 at 1:17 PM / IP Logged
I have purcahsed a AS80 form SPAL car alarm with keyless entry and need the wireing specs for the Sport trac in order to wire it.  does any one have the diagram.
snguyen
Silver - Posts: 281
Posted: November 06, 2004 at 1:40 PM / IP Logged
Ford
Explorer Sport Trac
2001-2004
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
RED / Lt. Blue
IGNITION SWITCH HARNESS *
Ignition  #1:
Lt. GREEN/ Purple
Ignition #2:
Brown
Ignition  #3:
Pink/Black
Accessory:
BLACK/ Green
Brake  Light:
Lt. Green
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
Tan / YELLOW
Engine Compartment Against Firewall Passengers Side
Parking Lights:
WHITE/ Black
Headlight Switch
Headlights:
RED / Yellow (-)
Headlight Switch
OEM Alarm  Disarm:
Drk. GREEN/ Purple (-)
Driver's Kick Panel
OEM Alarm  Arm:
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * Equipped with Ford's PATS Transponder Theft System. Use Universal Alarm Bypass Module part #2x402 where X can be any number.
Ford
Explorer Sport Trac
2001-2004
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
Yellow (+)
Ignition Switch Harness
Starter  Kill:
RED / Lt. Blue
Ignition  +12 Volts:
Lt. GREEN/ Purple
Dome  Lights/Superv:
See note below (-)**
See note below(-)**
OEM Horn:
Yellow/Lt. Green
Steering Column
Power  Lock:
Pink / YELLOW
Driver's Kick Panel***
Power  Unlock:
Pink/Lt. Green
Trunk  Release:
Alarm  Input Wire:
See note below(-)**
Notes:
** The wires will measure 12 volts with the doors closed and the wires will go to ground with the doors opened, Diode isolate each wire. The drivers door trigger wire is Yellow/Black found in the drivers kick panel. The Passengers door trigger is Gray/Red in the passengers kick panel. The drivers side, rear door color wire is GREEN/ YELLOW, This wire will also be located in the drivers kick panel. The Passengers rear door color wire is Pink/lt.blue. Also found in the passengers kick panel. *** If Equipped With Factory Keyless Entry - Negative Pulse Door Lock Diagram. Without Keyless Entry - Reverse Polarity Door Lock Diagram.
snguyen
Silver - Posts: 281
Posted: November 06, 2004 at 1:41 PM / IP Logged
 EXPLORER SPORT TRAC                    2004
WIRE COLORSLOCATION
12 VOLTS CONSTANTRED   "DO NOT USE"Connect directly to the Battery 12v Only
IGNITION 1LIGHT GREEN/ PURPLE (+)IGNITION SWITCH HARNESS
IGNITION 2PINK/BLACK (+)IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 1BROWN (+)IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2GRAY / YELLOW (+)IGNITION SWITCH HARNESS
STARTERRED / LIGHT BLUE (+)IGNITION SWITCH HARNESS
PARKING LIGHTS (+)BROWN at HEAD LIGHT SWITCH
DOME LIGHT SUPERVISIONBLACK/ LIGHT BLUE (+)in DRIVERS KICK PANEL located in harness going to rear of vehicle.
DOOR PIN TRIGGER (alarms)  See NOTE**
POWER DOOR LOCKPINK / YELLOWlocated in DRIVERS KICK PANEL in the DOOR HARNESS  (TYPE "B")   See NOTE***
POWER DOOR UNLOCKPINK/ GREENlocated in DRIVERS KICK PANEL in the DOOR HARNESS  (TYPE "B")    See NOTE***
TACH SENSORTAN / YELLOWat the PCM, Pin 96, located at the TOP of the FIREWALL, passengers side.
BRAKE
 LIGHT GREEN (+)at SWITCH on BRAKE PEDAL BRACKET
HORN
YELLOW/LIGHT GREEN (+)
in STEERING COLUMN HARNESS
             FACTORY ANTI-THEFTTRANSPONDER (Ford's SecuriLock) Requires part #791 bypass module and extra ignition key.
NOTE**        When connecting  use the YELLOW/BLACK (Drivers Door) (-) in the Drivers Door harness, in the PASSENGERS KICK PANEL use the GRAY/RED (-) for ALL other  Doors, you MUST USE ALL wires and DIODE ISOLATE when connecting to an Alarm system.
telesplicer
Posted: December 08, 2004 at 6:30 PM / IP Logged
Thank you for the Help.  Where is the ingnition harness I can not find it in order to finish the install.
Friday, January 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
