factory alarm disarm/arm wires?
sefrm0
Member - Posts: 8
Posted: November 06, 2004 at 10:26 PM / IP Logged
Remote starter Autopage 850 lcd added to a 1998 Chevrolet Suburban.  The factory remote, when unlocking the vehicle, also turns on the interior dome light for about 30 seconds and when locking the vehicle is turns it off within 3 or so seconds and honks the horn once. Is there a wire and/or wires that need to be connected for this to function with the aftermarket alarm for this vehicle? Could this feature be intergrated with an after market alarm? I would really appreciate any information.
Gage
Sexified
Copper - Posts: 87
Posted: November 06, 2004 at 11:37 PM / IP Logged
only disarm, it should be in the door boot or at the bcm under the dash behind the metal shroud that you need to remove 4 10mm nuts from. it's a light green, as far as re-arm, it will only work if you lock the doors with the r/s remote witht he door open. then when you shut the door the trucks alarm takes over.
sefrm0
Member - Posts: 8
Posted: November 14, 2004 at 6:47 PM / IP Logged
Thank you for the prompt reply.
Gage
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
