2001 Camry security wiring
meh66
Copper - Posts: 266
Posted: November 11, 2004 at 9:02 AM / IP Logged
Can send some give me the diagram for 2001 Camry. I found one here but I notice it did not mention anything about the door trigger. This vehicle do not have a factory security system.
MEH66
"Car Performance and Mobile Electronic Enthusiats"
snguyen
Silver - Posts: 281
Posted: November 11, 2004 at 10:09 AM / IP Logged
Toyota
Camry
1997-2001
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
RED
IGNITION SWITCH HARNESS **
Ignition  #1:
BLACK/ RED
Ignition #2:
BLACK / YELLOW
Ignition  #3:
N/A
Accessory:
BLUE/RED
Brake  Light:
GREEN / WHITE
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
BLACK ORANGE
AT ECM OR IGNITOR *
Parking Lights:
GREEN (+)
AT # PIN WHITE CONN. AT FUSE PANEL
Headlights:
RED / YELLOW (-)
AT HEADLIGHT SWITCH
OEM Alarm  Disarm:
RED / GREEN (-)
# PIN CONN IN DRIVER'S KICK PANEL
OEM Alarm  Arm:
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * ECM Is Located Behind The Glove Box. ** Beginning in 1998, this vehicle is equipped with a transponder type of theft system.
Toyota
Camry
1997-2001
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
WHITE/ RED & WHITE
Starter  Kill:
RED
Ignition  +12 Volts:
BLACK/ RED
Dome  Lights/Superv:
RED / WHITE (-)
7 PIN WHITE CONN. ABOVE FUSE PANEL
OEM Horn:
GREEN/ BLACK (-)
IN STEERING COLUMN HARNESS
Power  Lock:
LIGHT GREEN (-)
# PIN CONN IN DRIVER'S KICK PANEL ***
Power  Unlock:
DARK GREEN (-)
Trunk  Release:
N/A
Alarm  Input Wire:
RED / WHITE (-)
Notes:
** Child Safety Wire is BLUE/RED (-) in same connector as door locks.
snguyen
Silver - Posts: 281
TOYOTA CAMRY 2000-01
WIRE COLORSLOCATION
12 VOLTS CONSTANT
WHITE/ RED & WHITE
IGNITION 1BLACK / YELLOWIGNITION SWITCH HARNESS
IGNITION 2
BLACK/ RED
IGNITION 3N/AN/A
ACCESSORY /HEATER BLOWER 1BLUE/REDN/A
ACCESSORY /HEATER BLOWER 2       N/A
STARTERRED (+)IGNITION SWITCH HARNESS
PARKING LIGHTSGREEN (+)WHITE PLUG BOTTOM LEFT OF FUSE BOX
DOME LIGHTRED / WHITE (-)TOP RIGHT OF FUSE BOX WHITE 14 PIN CONNECTION
POWER DOOR LOCKDARK BLUE/WHITEORANGE PLUG AT BOTTOM OF FUSE BOX
POWER DOOR UNLOCKDARK BLUETYPE B   TEST WIRE USING KEY IN PASSENGER DOOR
TRUNK RELEASEBLUE/BLACK (+)DR KICK PANEL
TACH SENSORBLACK OR GRAYECM BEHIND GLOVE BOX 28 PIN PLUG PIN 27
BRAKE
GREEN / WHITEWHITE PLUG BOTTOM RIGHT OF FUSE BOX
HORN
GREEN/ BLACK
FACTORY DISARM
RED / GREEN (-)DR KICK PANEL WHITE 24 PIN CONNECTION
meh66
Copper - Posts: 266
Posted: November 11, 2004 at 10:20 AM / IP Logged
I know, I could just use the pin switch, but I wanted as much info as I could.
MEH66
meh66
Copper - Posts: 266
Posted: November 11, 2004 at 10:32 AM / IP Logged
MEH66
meh66
Copper - Posts: 266
Posted: November 12, 2004 at 8:16 AM / IP Logged
Thanks....Install went fairly smooth. Took me longer than I anticipated, but I was satisfied with the overall install. I am keeping my fingers crossed as this is the morning after, LOL.
MEH66
