Full Wiring Info On Nissan Murano 2003
SinX3
Member - Posts: 19
Posted: November 11, 2004 at 1:50 PM / IP Logged
Does Any One Know The Full Wiring Info On the 2003 Nissan Murano Or where to get it
They Can Hear His But Feel Yours Vermont Audio
snguyen
Silver - Posts: 281
Posted: November 11, 2004 at 3:17 PM / IP Logged
Nissan
Murano
2003-2003
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
BLACK/ Red & Black Yellow
Ignition switch harness**
Ignition  #1:
BLACK/ Red (+)
Ignition #2:
N/A
Ignition  #3:
N/A
Accessory:
WHITE/ Blue (+)
Brake  Light:
RED / Green (+)
Brake pedal switch
Tach  Signal:
Parking Lights:
RED / Blue (+)
Drivers kick panel to the rear
Headlights:
OEM Alarm  Disarm:
N/A
OEM Alarm  Arm:
N/A
Diesel  Glow Plug:
N/A
Clutch  Bypass Wire:
Notes:
 *This vehicle may be equipped with a Transponder Anti-Theft System. **This vehicle is equipped with two start wires. Both must be powered in order for vehicle to start when engine is cold.
Nissan
Murano
2003-2003
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
Green (+)
Starter  Kill:
Ignition  +12 Volts:
BLACK/ Red (+)
Dome  Lights/Superv:
Comes on with unlock
OEM Horn:
GREEN/ Orange (-)
Steering column harness
Power  Lock:
Blue (-)
Drivers door module in door***
Power  Unlock:
Red (-)
Trunk  Release:
N/A
Alarm  Input Wire:
Notes:
***Negative Trigger Door Locks
auex
Platinum - Posts: 5,041
Posted: November 11, 2004 at 3:38 PM / IP Logged
Full wiring info would be found in a service manual. Factory service manual's are best.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
SinX3
Member - Posts: 19
Posted: November 11, 2004 at 4:43 PM / IP Logged
Thanks Allot man
SinX3
Member - Posts: 19
Posted: November 11, 2004 at 4:44 PM / IP Logged
But what About the Pin Switch Does It Have It
Platinum - Posts: 12,488
Posted: November 11, 2004 at 5:00 PM / IP Logged
 yellow/black  -  pin switch under hood
SinX3
Member - Posts: 19
Posted: November 11, 2004 at 5:24 PM / IP Logged
One More Question Man My Dad WHent On A Busness Trip Yesturday To New Yourk And I Know How To Do all that Exept On Newer Models I Have No Clue Whats Up. Ime Only 16 this is my dads Account Now Pls Where exactly is the tach Light It Sais Behind Glove Compartment But There Is A sh*t load of whires That Are Yellow
SinX3
Member - Posts: 19
Posted: November 11, 2004 at 5:26 PM / IP Logged
New York*
auex
Posted: November 11, 2004 at 6:38 PM / IP Logged
Stop touching your dad's car until he gets back from New York. From your other posts, I can tell you don't know what you are doing. You can potentionally cause thousands of dollars worth of damages messing with this stuff. The wires you are tieing into go directly to the car's computer's and you should NOT touch these unless you know what you are doing and how to test for them correctly.
This is in no way flaming you but just don't touch it.
Posted: November 11, 2004 at 7:09 PM / IP Logged
Word !! Auex got a good point here. Why are you installing into your dad's vehicle ? Does he know about this installation that your toying with ? If you don't know how to test for a tach signal then I suggest you pack up what you have now and let a professional do the installation.
