1999 F150 radio problem
useful_idiot
Member - Posts: 11
Posted: November 16, 2004 at 5:51 PM / IP Logged
Hey, I just hooked up a remote start kit a couple of weeks ago. When I hooked it all up, my heater/air conditioner worked fine. NOW, when I start my truck with the remote, my heater blows cold air and the air conditioner blows hot air. This problem comes and goes. Sometimes it works right, sometimes it doesn't. ALSO, my radio shuts off and on all the time. It stays off most of the time. When it does work, it usually only works for about 5-10 minutes and then just shuts down. Any ideas? I was thinking maybe it had something to do with the accessory wire. But I unhooked it and I'm still having the same problem. I don't think that it was just a coincedence that my radio is malfunctioning and i need to repair the a/c system. I'm stumped here, someone help.
-idiot
draasch
Gold - Posts: 2,172
Posted: November 16, 2004 at 9:47 PM / IP Logged
Ignition 12 volts D BLUE/L GREEN IGNITION SWITCH HARNESS
Ignition #2 RED / BLACK IGNITION SWITCH HARNESS ** #235
Ignition #3 GRAY / YELLOW IGNITION SWITCH HARNESS ** #236
Accessory BLACK/ L GREEN IGNITION SWITCH HARNESS **
Ignition Switch Layout: Ignition #1 - D BLUE/L GREEN..........Powers Ignition Coil (Primary Ignition) Ignition #2 - GRAY / YELLOW.............Powers Blower Motor. Ignition #3 - L BLUE/PINK.............Powers Rear ABS Module. * Ignition #4 - RED / L BLUE..............Powers Heat/Ac Controls. ** Accessory - BLACK/ L GREEN.............Powers Radio & Windshield Wipers. * Wire Not Needed With 4 Wheel ABS. (Wires Present But Have No Function) ** RED / L BLUE Wire In Some Vehicles Is Found As RED / BLACK.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
ninjazx6e
Member - Posts: 11
Posted: November 16, 2004 at 9:48 PM / IP Logged
did you power up all three ignition wires and both(2) accesory wires?
ninjazx6e
Member - Posts: 11
Posted: November 16, 2004 at 9:50 PM / IP Logged
Accesory - RED / black
Second accesory - BLACK/ green
ninjazx6e
Member - Posts: 11
Posted: November 16, 2004 at 9:52 PM / IP Logged
ign 1 - dk blue/lt green
ign 2 - gray / YELLOW
ign 3 - lt blue/pink
