tach wire 2002 chevy siverado
grymus
Member - Posts: 36
Posted: October 10, 2002 at 1:40 PM / IP Logged
can anyone tell me where to grab the tach wire and what color it is on a 2002 chevy silverado 2500HD?  I know i asked this before but lost my note on it.  Also same truck I have the negative door triggers where when the door is opened the wire goes to ground.  So i looked at that the digram on the 12volt page to diode the wires to the alarm it seemed backward to me.  Which side does the strip on the diode go to..the alarm side or the trigger side?
Thanks,
Ryan
SnomanF150
Silver - Posts: 269
Posted: October 10, 2002 at 2:13 PM / IP Logged
if you are looking for a tach for a remote start, you can get it at an injector.. just look at the injectors and use the wire that is not common.. I believe a pink is common on the injectors.. has to be a programming tach type of remote start I believe for this to work..
the strip/band side of the diode will go to the trigger side to allow (-) to go the alarm..
George
David's Car Stereo
Baton Rouge, LA
securinu
Silver - Posts: 772
Posted: October 10, 2002 at 5:02 PM / IP Logged
you can also get the white wire @ the pcm. this is located to the left front of the engine. there are 2 white wires so you have a 50/50 chance of getting it right on the first try. this is an 8 cylinder signal.
grymus
Member - Posts: 36
Posted: October 10, 2002 at 6:48 PM / IP Logged
is there anyone who can tell me which wire it is in the PCM?
securinu
Silver - Posts: 772
Posted: October 10, 2002 at 7:42 PM / IP Logged
pin 10 of the 80 pin connector , but there not labeled so just dig into the harness and pull the 2 white wires.
