2001 Lexus IS300
Camz
Posted: November 22, 2004 at 7:34 PM / IP Logged
Need any info on installing alarm/remote start in 2001 Lexus IS300. Cannot find wiring codes on any site.
draasch
Gold - Posts: 2,172
Posted: November 23, 2004 at 5:20 AM / IP Logged
Make:   Lexus
Model: IS300
Year:    2001
Alarm
Constant 12 volts WHITE & WHITE/ RED IGNITION SWITCH HARNESS
Ignition 12 volts BLACK/ RED IGNITION SWITCH HARNESS
Starter BLACK/ WHITE IGNITION SWITCH HARNESS
Dome Light INDV.DOOR TRIGGERS (-) ECU ATTACHED TO TOP OF FUSE BOX *
Trunk Pin Switch RED / YELLOW (-) DRIVER KICK PANEL
Parking Lamp GREEN (+) DRIVER KICK PANEL
Power Lock
Power Unlock
* Door Triggers Are: RED / GREEN - Driver, RED / BLACK - Passenger Front, RED / WHITE - Rear Doors. All Triggers Are Negative Diode Isolation Required
Remote Start
Tach Signal BLACK IGNITER #2
Ignition #2 BLUE/RED IGNITION SWITCH HARNESS
Ignition #3
Accessory RED IGNITION SWITCH HARNESS
Neutral Safety
Brake Light GREEN / WHITE (+) AT SWITCH ABOVE PEDAL
Reverse Light
Rear Window Defrost
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
raydawg357
Silver - Posts: 769
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
