2002 Mitsubishi Galant Help
massivegrk
Member - Posts: 38
Posted: November 26, 2004 at 11:27 PM / IP Logged
installing an alarm on a 2002 Galant and i can't find the parking light wire.  Its says it's a GREEN / WHITE + wire.. I don't see that color wire anywhere near the fuse box.... Checked wires all around there and from parking light switch with multimeter and can't find a wire that responds to the parking lights on and off..Am i supposed to be loooking at the fuse box under the hood?   Aren't most mitsubishi's negative relays?  Would appreciate any help.. Thakns
draasch
Gold - Posts: 2,172
Posted: November 27, 2004 at 9:03 AM / IP Logged
use your meter.....you should be able to find it.....
Parking Lamp GREEN / WHITE (+) BY FUSE BLOCK UNDER DRIVERS DASH
i checked 2001-2004 and have the same info......it should be there......
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
massivegrk
Member - Posts: 38
Posted: November 27, 2004 at 10:04 AM / IP Logged
Thanks i'll check again
Sunday, November 9, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
