OEM Keyless Entry 1996 Mazda 626
nnam_t
Member - Posts: 7
Posted: April 24, 2002 at 8:31 AM / IP Logged
I have a Avital 3200 Remote start with keyless entry unit.  I have the remote start part hooked up but I need help with hooking up the keyless entry.  My car has OEM keyless entry and secuirty.  What wires do i need to hook up to the avital unit. I need the Lock,Unlock(s) wires and Factory Disarm wire.
Please...any help will be appreciated.
Platinum - Posts: 12,488
Posted: April 24, 2002 at 10:44 AM / IP Logged
Mazda
626
1996
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
BLACK (2)
IGNITION SWITCH HARNESS
Starter  Kill:
BLACK / YELLOW
Ignition  +12 Volts:
BLACK/ WHITE
Dome  Lights/Superv:
RED / WHITE (-)
26 PIN CONN. IN DRIVER KICK PANEL **
OEM Horn:
GREEN/ ORANGE (-)
STEERING COLUMN HARNESS
Power  Lock:
ADD ACTUATOR
IN DRIVER'S DOOR ****
Power  Unlock:
ADD ACTUATOR
Trunk  Release:
L GREEN/ RED (-)
AT CENTRAL PROCESSING UNIT
Alarm  Input Wire:
RED / WHITE (-)
Notes:
** RED / WHITE (-) Wire Also Located At Central Processing Unit In Driver Kick Panel. *** L GREEN (-) At Headlight Switch Can Also Be Used For Parking Light. ****   Add Actuator Door Lock
Factory DisarmYellow/Red (-) Behind Fuse Panel
You will need to install door lock actuators to the door lock on the driver side.You can go to this link for the relay configuration of the actuators: https://www.the12volt.com/doorlocks/page3.asp#arp
