diagram for a 2004 grand cherokee
jay's detailing
Member - Posts: 24
Posted: December 01, 2004 at 1:39 PM / IP Logged
looking to see if any one out there has a diagram for a 2004 grand cherokee. I;m Installing a audiovox prestige aps786 alarm and remote start combo.. I need to knoe if this vehicle needs a transponder if so witch one do i need and I need to know the power door lock system.. (diagram if possible)... thanx ...Angel
snguyen
Silver - Posts: 281
Platinum - Posts: 12,488
Posted: December 01, 2004 at 5:27 PM / IP Logged
The JDL-PK will bypass the Sentry key as well as interface with the door lock system. Make sure that your ground out when running wire on the Audiovox is relayed like this: http://www.velocitymotorsport.com/images/install_notes/N2N.jpg to ensure a proper ground going to the module. If you don't you will run into problems with intermittent locking and disarming and possible no starts when remote starting. When you pruchase the JDL-PK it will already come with wiring instructions for your Jeep and the wiring diagram for the 04 Jeep you can get here:
2004 Wiring Diagram Link
