97 toyota 4runner- lock/unlock 2 options?
vermonster
Posted: December 08, 2004 at 12:39 PM / IP Logged
I have a 1997 Toyota 4Runner SR5 5spd with original electric locks--but no alarm or keyless entry.
Am going to install aftermarket keyless entry system. Have found some wiring information here, but am confused on two issues:
It seems there are two lock/unlock wires. One set that goes to the door key cylinder and the other to the interior switch on the driver's door. When using the door key, it is possible to unlock only the driver's door, then with a second turn all doors. I would like to do this with keyless as well (press once, driver's; press twice, all). Is this possible?
Also, I see some remarks here about using the key cylinder wires to avoid the issue with the Toyota child lock system. Can anyone confirm?
Any additional wiring diagrams appreciated either posted here or by e-mail (in profile).
vermonster
Posted: December 09, 2004 at 10:56 AM / IP Logged
**cough** anyone?
secureauto
Copper - Posts: 197
Posted: December 11, 2004 at 11:44 PM / IP Logged
Does your aftermarket keyless entry offer a second unlock wire? if it does, tag the key cylinder wire with both unlock wires and program feature for split unlocking (if applicable). If not use your unlock for the dirver door and 2nd channel output to unlock the other doors. I've added a wiring diagram that I found.
You can also test to see if it has the child safety feature, roll down driver window lock door with key, reach in and see if it will unlock with doorlock switch if it doesnt unlock, you have the child safety feature.
DIRECTWIRE™ WIRING INFORMATION - TOYOTA / 4RUNNER / 1997 / Security
12volts white - WHITE/ red    +   ignition harness
Starter black    +   ignition harness
Ignition BLACK / YELLOW    +   ignition harness
Power Lock RED / white    -   10 pin plug, left of fusebox
Power Unlock RED / yellow    -   10 pin plug, left of fusebox
Lock Motor
Unlock Motor
Disarm Defeat
Parking Lights+ green      white plug, front of fusebox
Parking Lights- RED / white      steering column
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger BLACK/ white    -   DKP, harness to rear
Dome Supervision use door trigger
Trunk/Hatch Pin RED / white    -   DKP, harness to rear
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer black    ac ignitor or diag. plug
Notes: Ignitor is on passenger side fender well. Diagnostic connector is on drivers side top of motor.
Horn Trigger GREEN/ red    -   steering column
ASE Certified
