Need wiring diagram for honda accord 2004
hondacc99
Member - Posts: 11
Posted: December 09, 2004 at 3:35 PM / IP Logged
i need a wiring diagram for honda accord 2004. anyone please help.........thanks
snguyen
Silver - Posts: 281
Posted: December 09, 2004 at 4:31 PM / IP Logged
2004 Honda Accord
Constant: white (+) @ Ignition Harness
Ignition: BLACK / YELLOW (+) @ Ignition Harness
Starter: BLACK/ white (+) @ Ignition Harness
Accessory: BLACK/ red (+) @ Ignition Harness
Accessory 2: WHITE/ red (+) @ Ignition Harness
Keysense: RED / white or RED / black (-) @ Ignition Harness
Horn Trigger: GREEN/ YELLOW (- ) @ Steering column
Power Lock: pink/black (-) Green plug, Left side of fusebox
Power Unlock: pink/blue (-) Green plug, Left side of fusebox
(Meter using the passeneger door switch)
Lock Motor: yellow/black (5 wire) Green plug, front of fusebox
Unlock Motor: YELLOW /GREEN (5 wire) Green plug, front of fusebox
Parking Lights: RED / black (+) Large white plug above fusebox
Parking Lights 2: BLACK/ red or blue/red (-) in steering column cover
Reverse Light: green (+) @ Drivers kick, harness to rear
Door Trigger: GREEN/ red (-) Green 5 pin plug behind fusebox
Trunk Release: YELLOW /GREEN (+) @ Drivers kick, harness to rear
Trunk Pin: blue/black (-) @ Drivers kick, harness to rear
Hood Pin: yellow/red (-) hood pin switch in latch
Factory Alarm Arm: WHITE/ red (-) @ Driver door module in door
Factory Alarm Disarm: white (-) @ Driver door module in door
Tachometer: blue/red or blue (ac) @ ECM/PCM
(The ECM/PCM is on the front of the transmission tunnel. The connectors are on the passenger side. On the 4 cylinder models the tach wire is in the white 31 pin connector E, pin 25. On the 6 cylinder models it is in the gray connector A, pin 23.)
Brake: WHITE/ black (+) brake pedal switch
Parking Brake: GREEN/ orange (-) Large white plug above fusebox
Bypass: PK3
