vats question ?
Legrones
Copper - Posts: 75
Posted: December 13, 2004 at 6:02 PM / IP Logged
if i wont to buypass a vats system all i do is cut the two white wires in the yello loom and put the resistor that i need on the brain side of the white wires ?
Dale / Cory
kgerry
Platinum - Posts: 3,455
Posted: December 13, 2004 at 6:09 PM / IP Logged
use a relay... and insert the resistor with the relay
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
secureauto
Copper - Posts: 197
Posted: December 15, 2004 at 12:33 AM / IP Logged
Here's a link, hope it helps
Vats Bypass
ASE Certified
albad4u
Posted: December 24, 2004 at 7:47 PM / IP Logged
there are 2 white wires on the key side of the plug but they are color coded on the other side. its no need to cut both wires just 1 is fine with a relay and correct resistance or u could use a universal alarm bypass learning ordial in either works great
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
