2003 GMC and a Valet 554R help please
fooser
Member - Posts: 15
Posted: December 16, 2004 at 8:18 PM / IP Logged
Can somebody please take a look at this and let me know if I’ve got it wired right, and help me with the ones I’m not sure about.
2003 GMC Sierra, 2 door, automatic, and no power door locks
DEI Valet 554R, GMDL-BP, and a power door lock kit
Primary harness H1
RED / white – (-)200mA ch2 validity output = not sure?
Red – (+)12 volt constant
Brown – Siren (+) output
Black – Chassis ground
Violet – (+) door trigger = all door trigger (+)gray/ black wire in drivers “A” pillar
Blue – optional sensor = not used
Green – (-) door trigger = since im using the +door trigger, will I need this?
BLACK/ White – (-)200 mA dome light supervision = not sure?
WHITE/ Blue – (-) remote start activation= not sure?
White – Selectable light flash= vehicle light switch (-)violet wire
Orange – (-)500 mA ground when armed output= not used, since the 554R has the starter kill built in, I think this is right?
Secondary Harness H2
Gray/Black – Wait to start input (for Diesels) = not used
Light GREEN/ Black – Factory disarm/special accessory output = not sure?
Violet/Black – programable channel 4 output = not used now, maybe a future upgrade like an electric tailgate lock?
Relay Satellite Key Switch Interface
All wires go to the relay block, so coming out of relay block
Pink – (-)200 mA First and second ignition relay turn on= Key side ignition #1 pink wire, wiring diagram for truck also shows a #2 ignition white wire, what do I do with this wire? and what about the Starter #1 yellow wire?
Purple – Starter side ignition #1 pink wire
Orange – accessory output – not sure, wiring diagram for truck has acc1 (orange wire) and acc2 (brown wire)
Remote Start Harness H3
Blue – (-)200 mA status/factory security rearm output = not used?
Blue/Black – (-)200 mA optional third ignition output = not used?
Gray – hood pin switch = self explanatory
Brown – (+) Brake switch shutdown = White wire at brake pedal switch
Violet/White – Tach input wire = instrument cluster white wire
BLACK/ White – (-) neutral safety switch = I know I need this but what wire on the truck do I use, and where is it located on this truck?
Door Lock Harness H4
Green – (-) lock (+) unlock output = I’ll have to use a DMM and test the wires coming out of the actuators
Blue – (-) unlock (+) Lock output = I’ll have to use a DMM and test the wires coming out of the actuators
That’s all the Harness’s, now I’m wondering how to wire the GMDL-BP into this?  Any help would be appreciated.
fooser
Member - Posts: 15
Posted: December 16, 2004 at 8:21 PM / IP Logged
Sorry dont know what happened, I'll try again
KarTuneMan
Platinum - Posts: 7,056
Posted: December 23, 2004 at 10:55 PM / IP Logged
I thought I was being contacted by ALIENS...............2003 GMC and a Valet 554R help please -- posted image.
Monday, December 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
