2003 mazda tribute diagram plz.
Alpine Guy
Platinum - Posts: 2,478
Posted: December 18, 2004 at 11:38 AM / IP Logged
The autostart web site wont load, so i need a diagram for a customers 09/02 mazda tribute.
thanks
KarTuneMan
Platinum - Posts: 7,056
Posted: December 18, 2004 at 4:00 PM / IP Logged
I have tried to post a sheet for ya.......but I think they are workin out some bugs on the web sight.
KarTuneMan
Posted: December 18, 2004 at 8:15 PM / IP Logged
Factory Alarm Arm WHITE/ purple  -  DKP or 26 pin plug @ GEM   2003 mazda tribute diagram plz. -- posted image.
Factory Alarm Disarm blue/lt. green  -  DKP or 26 pin plug @ GEM   2003 mazda tribute diagram plz. -- posted image.
KarTuneMan
Posted: December 18, 2004 at 8:20 PM / IP Logged
12volts
 RED / lt. blue (10A)
 ignition harness
Starter tan/lt. blue  +  ignition harness
Second Starter N/A
Ignition lt. GREEN/ purple  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory BLACK/ lt. green  +  ignition harness
Second Accessory N/A
Keysense BLACK/ pink  +  ignition harness
Power Lock pink/white  -  DKP or 26 pin plug @ GEM
Power Unlock same wire as power lock
Lock Motor pink/black  5wi DKP or 26 pin plug @ GEM
Unlock Motor RED / orange  5wi DKP or 26 pin plug @ GEM
Parking Lights+ brown  +  driver kick panel
Parking Lights- BLACK/ lt. green  -  column or 22 pin plug @ GEM
KarTuneMan
Posted: December 18, 2004 at 8:39 PM / IP Logged
Door Trigger PURPLE / lt. green  -  cluster or GEM, 22 pin plug, pin 10   2003 mazda tribute diagram plz. -- posted image.
Dome Supervision lt. GREEN/ orange  -  dome lt or GEM, 26 pin plug, pin 1   2003 mazda tribute diagram plz. -- posted image.
Trunk/Hatch Pin common with door trigger
Hood Pin PURPLE / orange  -  pin sw or GEM, 22 pin plug, pin 16   2003 mazda tribute diagram plz. -- posted image.
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm WHITE/ purple  -  DKP or GEM, 26 pin plug, pin 20   2003 mazda tribute diagram plz. -- posted image.
Factory Alarm Disarm dk. blue/lt. green  -  DKP or GEM, 26 pin plug, pin 19   2003 mazda tribute diagram plz. -- posted image.
Disarm No Unlock see factory alarm disarm
Tachometer NOT WHITE/ purple or red  ac  any ignition coil or fuel injector
Wait to start N/A
Brake Wire lt. green  +  brake pedal switch
Parking Brake lt. GREEN/ red  -  parking brake switch
Horn Trigger YELLOW /GREEN  -  column or GEM, 22 pin plug, pin 19
KarTuneMan
Posted: December 18, 2004 at 8:44 PM / IP Logged
Door TriggerPURPLE / lt. green - cluster or 22 pin plug @ GEM 2003 mazda tribute diagram plz. -- posted image.
Dome Supervisionlt. GREEN/ black driver door harness 2003 mazda tribute diagram plz. -- posted image.
Trunk/Hatch Pin
Hood PinPURPLE / orange - pin sw or 22 pin plug @ GEM 2003 mazda tribute diagram plz. -- posted image.
Trunk/Hatch Release
Power Sliding DoorN/A
Factory Alarm ArmWHITE/ purple - DKP or 26 pin plug @ GEM 2003 mazda tribute diagram plz. -- posted image.
Factory Alarm Disarmblue/lt. green - DKP or 26 pin plug @ GEM 2003 mazda tribute diagram plz. -- posted image.
Disarm No Unlocksee factory alarm disarm
Tachometer ac ignition coil or coil pack 2003 mazda tribute diagram plz. -- posted image.
Wait to startN/A
Brake Wirelt. green + brake pedal switch
Parking Brake
Horn Triggeryellow/lt. green - steering column 2003 mazda tribute diagram plz. -- posted image.
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module
PLEASE DO'NT USE THE LAST POSTED INFO.........I GAVE INFO FOR THE WRONG YEAR
Alpine Guy
Posted: December 18, 2004 at 8:53 PM / IP Logged
I managed to getter done without any info, took 4 hours, All i gota do is finish the door locks , can't test the multiplex, now that i have the diagram i'll call the customer back in to finish them.
Thanks alot
Monday, December 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
