2002 chevy tahoe remote start
JRoscoe
Member - Posts: 29
Posted: December 18, 2004 at 11:42 AM / IP Logged
Im going to instrall a remote start on a 2002 tahoe and wondered where the best place to get a vehichle diagram was?  Plus any tips would be helpful, as this is a new vehicle to me.
KarTuneMan
Platinum - Posts: 7,056
Posted: December 19, 2004 at 2:11 AM / IP Logged
12volts
 red
 ignition harness
Starter yellow  +  ignition harness
Second Starter N/A
Ignition pink  +  ignition harness
Second Ignition white  +  ignition harness
Third Ignition N/A
Accessory orange  +  ignition harness
Second Accessory brown  +  ignition harness
Keysense lt. green  -  ignition harness
Power Lock lt. blue  +  pin A4, brown plug at BCM
Power Unlock white  +  pin A3, brown plug at BCM
Lock Motor gray  5wi driver kick, door harness
Unlock Motor tan  5wi driver kick, door harness
Parking Lights+ brown  +  pin B6, lt. blue plug at BCM
Parking Lights- white  -  pin A5, lt. blue plug
KarTuneMan
Posted: December 19, 2004 at 2:12 AM / IP Logged
Door Trigger - BCM
Use tan for the driver door located in pin B4 of the purple plug, and the passenger doors are a blue/white in pin B11 of the lt. blue plug. Use both wires and diode isolate each.","CHEVROLET, TAHOE, 2002, Door Trigger");' rel="nofollow" href="http://www.directechs.com/directwire/wire_body.asp?action=select&yr=3450&product=Remote Start#">2002 chevy tahoe remote start -- posted image.
Dome Supervisionuse door trigger
Trunk/Hatch Pinpink/black - pin B10, lt. blue plug at BCM 2002 chevy tahoe remote start -- posted image. 2002 chevy tahoe remote start -- posted image.
Hood PinN/A
Trunk/Hatch ReleaseN/A
Power Sliding DoorN/A
Factory Alarm Armarms on lock
Factory Alarm Disarmlt. green - pin B3, purple plug at BCM 2002 chevy tahoe remote start -- posted image.
Disarm No Unlocksee factory alarm disarm
Tachometerwhite ac ECM 2002 chevy tahoe remote start -- posted image.
Wait to startdk. blue - instrument cluster
Brake Wirewhite + brake pedal switch
Parking BrakeGREEN / WHITE - parking brake switch
Horn Triggerblack - pin A9, brown plug at BCM 2002 chevy tahoe remote start -- posted image. 2002 chevy tahoe remote start -- posted image.
Memory Seat 1white + memory mod under dr seat
Memory Seat 2purple + memory mod under dr seat
Memory Seat 3N/A +
Immobilizer Bypass Module
MAKE : CHEVROLET | MODEL : TAHOE | YEAR : 2002
KarTuneMan
Posted: December 19, 2004 at 2:20 AM / IP Logged
Check for a 3rd ign. wire pink/white. power that wire if its there!
Also pulse the drivers door (-) pin wire (tan @ bcm) to shut the radio off after the run time.
Astroflex rules............
JRoscoe
Member - Posts: 29
Posted: December 19, 2004 at 5:05 PM / IP Logged
thats great thanx
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
