Viper 791XV remote start on 2004 Explorer
jonkolo
Member - Posts: 13
Posted: December 22, 2004 at 7:41 PM / IP Logged
Hello, I installed a Viper 791XV on my 2004 V-8 Explorer.
My problem;
If the Explorer sits long enough for the engine to get cold, the remote start needs to make two attempts to start the engine.  The first attempt cranks the starter too briefly to start the engine, and the second attempt is always successful.  Again, this is only if the truck sits for an extended time period or the engine has time to completely cool off.
I connected the tach wire to an un-common fuel injector wire, since I was not able to sucessfully learn a signal from a coil wire.
During the first attempt, it seems like the Viper is getting a premature tach signal from the fuel injector.  It must be enough to make the viper think the engine started, therefore stoping the starter cranking too early.
What can I do to solve the problem? Any help would be appreciated.  Thanks
vinman75
Copper - Posts: 63
Posted: December 22, 2004 at 10:05 PM / IP Logged
I had a similar problem on the same vehicle. Ever since I swithced to voltage sensing and took the tach wire out it hasn't been back.
jonkolo
Member - Posts: 13
Posted: December 26, 2004 at 9:19 PM / IP Logged
What crank time did you program?  My Explorer needs to crank a lot longer when the engine is cold, so I expect problems with cranking too long or too short if I eliminate the tach wire and do that.
Moderator - Posts: 12,488
Posted: December 26, 2004 at 10:50 PM / IP Logged
How long did you allow the vehicle to idle before you learned the tach signal ?
jonkolo
Member - Posts: 13
Posted: December 27, 2004 at 8:16 PM / IP Logged
I learned it as soon as the engine started.  The viper installation guide said to do it within 5 seconds.  The LED came on, just like they said.
I would really like to fix this problem.  Any help would be appreciated.  Thanks
Scott35
Silver - Posts: 258
Posted: December 27, 2004 at 8:26 PM / IP Logged
What he means is, did you let the vehicle warm up before you learned the tach signal?
Tacomacrew
jonkolo
Member - Posts: 13
Posted: December 27, 2004 at 9:09 PM / IP Logged
No, it was cold.   ?????????
