1998 Oldsmobile Intrigue Tach wire
Brando
Member - Posts: 22
Posted: December 24, 2004 at 12:05 AM / IP Logged
Hi, the car I am installing a remote start on has a tachometer, can I just run a wire straight to that to use tach mode? The car is a 1998 Oldsmobile Intrigue. Thanks.
~Brandon
secureauto
Copper - Posts: 197
Posted: December 24, 2004 at 1:30 AM / IP Logged
Here's a link for the wiring diagram, it indicates to tag the tach wire at the ECM or at ignition module.
Wiring diagram
ASE Certified
Brando
Member - Posts: 22
Posted: December 24, 2004 at 10:50 PM / IP Logged
Thanks!
That diagram helped out a lot, got it installed and works great. Thanks again.
Brando
Member - Posts: 22
Posted: December 26, 2004 at 2:12 AM / IP Logged
Well, I had at first done tachless mode.  But now I've decided to do tach mode because it's single digit temperatures here in Michigan and tachless mode isn't cutting it.  So ECM is located in the engine compartment, where's the Ignition Module located? Is that just the Coil? I've also heard you can hook the tach wire up to the Fuel Injector wire, is this true?
Moderator - Posts: 12,488
Posted: December 26, 2004 at 9:47 AM / IP Logged
Use any of the injector wires that are NOT PINK in color.
Brando
Member - Posts: 22
Posted: December 26, 2004 at 5:50 PM / IP Logged
Well, I used one of the injector wires, but it's not learning from that wire (yellow/black).  Guess I'll try it at the coil.
Brando
Member - Posts: 22
Posted: December 26, 2004 at 6:45 PM / IP Logged
Yep, I hooked it up to the PURPLE / white wire at the coil and that worked.  Thanks for all the help.
Sunday, November 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
