2004 Dodge Ram 1500
willieb03
Posted: December 26, 2004 at 5:55 PM / IP Logged
I put a 4500 I.C. Dynamics Combo alarm;starter unit every thing works except the unlock I have changer to double pulse single pulse 1 sec. to3 sec with noresults I have sent the unit in for replacement .I got the new unit and wired it up and checked the signals to the lock and unlock it sends a signal. But it won't unlock I have checked the wires but no luck. Any Suggestions?
profuse007
Gold - Posts: 2,015
Posted: December 26, 2004 at 6:10 PM / IP Logged
DODGE, RAM PICKUP, 2004, Power Lock
Lock is negative trigger thru an 820 ohm resistor. Unlock is negative trigger thru a 330 ohm resistor. MUST use relays.
Power Lock      PURPLE / dk. green       -       driver kick, door harness
Power Unlock      same wire as power lock
Houston,TX
KarTuneMan
Platinum - Posts: 7,056
Posted: December 27, 2004 at 12:26 AM / IP Logged
If your truck has factory security....the wire is PURPLE / blue its located in the same connecter as the other wire
lock is 1.8k ohms      unlock is 450 ohms    set you brain to double unlock pulse
Thursday, April 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
