R/S on 98 Jeep Grand Cherokee
ironhorsect
Member - Posts: 9
Posted: January 01, 2005 at 11:59 AM / IP Logged
Hey all:
First Post is a question...I know, bad form ediquite...
I put a remote start system on my 98 limited.  I set it up to work with the factory keyfobs (three lock pulses) and it starts fine.  However, while the car is running, the rest of the keyfob is inoperable, just like if the key was in the ignition.  Does anyone know how I can disable this feature so I can use the factory keyless to start the car and then unlock the doors while it is running?  Wire colors are helpful as my schematic is crap.  No transponder or anything on this model to worry about.
Brennan
swamprat323
Gold - Posts: 1,335
Posted: January 01, 2005 at 1:09 PM / IP Logged
If the system does lock out the remotes, only thing i can think of is shut the RS part down form the remote then unlock your doors. Or put in in a whole new system abd with that you have better range then the OEM ones. I dotn think there a way to change it to the way you want.
Ravendarat
Platinum - Posts: 2,806
Posted: January 01, 2005 at 5:13 PM / IP Logged
As far as I know that is a permanent feature that cannot be disabled.
