Unlock works - lock does not
mrwhitehat
Member - Posts: 14
Posted: January 02, 2005 at 8:57 PM / IP Logged
99 Dodge Ram
Marksman M6A Keyless
Status:  Unlock works great - both remote and door switch
LOCK does not work
I have tried just connecting the lock switch wire to 87A and motor side lock wire to 30 (this should be closed by default) and it still does not work.  The switch is fine (tested).  I have tried 3 different relays.
Stumped and have worked with another installer who is also stumped.
Have also tried the following configuration as recommended in a previous post:
unlock relay:
86 output from alarm (unlock)
87a switch side
30 motor side
87 12 volts
85 12 volts
lock relay:
86 12 volts
87a switch side
30 motor side
87 12 volts
85 output from alarm (lock)
Thanks!
Craig3708
Copper - Posts: 155
Posted: January 02, 2005 at 9:07 PM / IP Logged
Lock and unlock are wired different on this truck. Wire the lock side as follows
 Pin 85 to lock from r/s
 Pin 86 & 87 +12volt
  Pin 30 to lock wire in truck  (rejoin your lock wire, and tap into it)
  Craig
mrwhitehat
Member - Posts: 14
Posted: January 02, 2005 at 9:19 PM / IP Logged
Thanks craig, worked great, wish this had been in the many, many pages I downloaded, purchased, and the many posts from other members - you rock and are our hero!  three cheers for Craig!
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
