2003 hummer H2 sunroof
Uniqueauto
Copper - Posts: 73
Posted: January 04, 2005 at 1:29 PM / IP Logged
Does anyone have any info as to what wire colors is the sunroof (open/close)for a 2003 Hummer H2? Im going to use a DEI 529T, also any info on how to interface would be greatly needed.
avxtech
Member - Posts: 35
Posted: January 04, 2005 at 2:52 PM / IP Logged
There are 3 wires at the switch. brn, org, yell.
brown = open (-)
org = close   (-)
yell = 12 volts
Can also find the wires at the sunroof mod in front of the headliner.
hope this helps
KarTuneMan
Platinum - Posts: 7,056
Posted: January 04, 2005 at 2:53 PM / IP Logged
tilt up and close are orange POS(+)
tilt down and open are brown POS(+)
15 second "pulse" they are limit switch protected......
Uniqueauto
Copper - Posts: 73
Posted: January 04, 2005 at 6:03 PM / IP Logged
ok thanks, so if I give the org wire postive it will close and the yellow will open with a postive.. So I won't even need a window module? Can't I just use a relay with a timer?
Uniqueauto
Copper - Posts: 73
Posted: January 04, 2005 at 6:05 PM / IP Logged
sorry I meant Brn will open
KarTuneMan
Posted: January 05, 2005 at 6:33 PM / IP Logged
Yes.....timed relay will do it.......
Wednesday, February 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
