2001 Lincoln LS Problems with 555s
michaelscheetz
Posted: January 06, 2005 at 7:22 PM / IP Logged
I can't seem to get the 555s programed. I used two seperate keys and still no go. Any suggestions?
dfiddy
Copper - Posts: 162
Posted: January 06, 2005 at 8:21 PM / IP Logged
Make sure that both the keys start the car. It won't learn if one of the keys isn't programmed. Could also be a faulty 555s...it's happened to me .
tjdurham
Copper - Posts: 180
Posted: January 06, 2005 at 11:36 PM / IP Logged
the 555s is most likely bad use a key in box you can get a key from Howard Keys for about $8 and will work every time
tj
Wednesday, November 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
