Prostart 3in1 5060 and 91 4dr 5spd civic
boomgawd
Posted: January 08, 2005 at 2:24 PM / IP Logged
HELP!!!
I got the install done, leared the remotes, then all the sudden after tring to program some of the features, the alarm was triggered and the remotes stopped responding....
Now no matter what I do, the alarm is set off. I can unplug the brain than plug it back in, but right away the alarm is triggered again and the remotes dont work.
I've tried the factory reset proccedures with the alarm running but it doesnt work(I'm assuming because the alarm is triggered)..
This all happened last night and I had to pull the brain to drive home. I'm willing to go at it again this evening but I need some help..
The install was done at a friends shop and he is a licenced mechanic, he is confided all the wireing is done right. (the fact that it was working and we did once learn the remote codes should mean something no???)
Anyways I'm new here but I dont know where to turn, if anyone has an opinion let me know!..
thanks in advance,
Al.
Craig3708
Copper - Posts: 155
Posted: January 08, 2005 at 5:20 PM / IP Logged
Constant up to 60 seconds
  1. Alarm condition generated by an intrusion, by triggering Panic Mode, or when the Module is powered up.
Plug the module in and let it alarm for at least 60sec, it should  stop. You should be able the shut off panic mode by pressing lock and unlock at the same time. You may need to go through the transmitter learning process and programing again.
              Good Luck
                 Craig.
boomgawd
Posted: January 08, 2005 at 7:07 PM / IP Logged
craig, it looks like you cut and past that from somewhere.. do you have a link to online docs?? that could help too. the manual that came with it is pretty lame.. anyways I'll try what you mentioned tomorow and let you all know if it helped.. if anyone else has an oppinion, please the more things I can try on knowledge I can ingest here the better luck I'll have tomorow..
Thanks agian,
Al.
Craig3708
Copper - Posts: 155
Posted: January 08, 2005 at 10:17 PM / IP Logged
boomgawd
Posted: January 08, 2005 at 10:20 PM / IP Logged
Craig you rock.. Thanx a tun!!!
Al.
Monday, April 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
