Best vs Acceptable Connections
dljbrla
Member - Posts: 23
Posted: October 22, 2002 at 10:44 AM / IP Logged
I'm new here , but have learned a lot in the last few days. One thing I learned, I think that you guys could wire the space shuttle!!Best vs Acceptable Connections -- posted image.A question please to installers that make quality wire connections everyday. I know that soldering is probably the best way for connecting into the larger / higher amp wiring for auto start systems. My question is, what are other methods that are proven to be acceptable, ie. Scotch wire taps (of the proper size ofcourse), tee taps, others?? When are the "easier" methods ok? Please share your experience.Best vs Acceptable Connections -- posted image.
thanks,
Danny
crraig wilson
Member - Posts: 13
Posted: October 22, 2002 at 11:15 AM / IP Logged
t-taps installed correctly and sized correctly in a low current demand circuit should be ok...
craig wilson
tech_advice
Member - Posts: 45
Posted: October 22, 2002 at 4:19 PM / IP Logged
If it's at all possible to solder, there are no other acceptable ways to connect...if you have room to crimp, scotch lock, or tee tap, you should have enough room to solder. This is just my biast opinion, but the bias comes from seeing too many burnt cars and too many install from other shops that I had to fix because the locks didn't hold or melted......hopes this helps(in some way).
Don't share too many install secrets with your customers, pretty soon they won't need you!!!!!
NyxBass
Silver - Posts: 226
Posted: October 22, 2002 at 6:14 PM / IP Logged
Admittedly, soldering  and shrink tubing is the best connection. But often, the time and effort = expense is not quite worth it. I have good luck with crimps as long as I buy quality crimps, crimp well, and check your crimps (PULL on the wire from both sides, HARD). If it stays, then you have a good crimp. You'll go through a few extra crimps, but have WAY less problems.
/NyxBass
