323 mazda 1993
Benooneb
Posted: January 16, 2005 at 1:06 AM / IP Logged
is there any passlock security system on those car  im 1993?
does any body as any wirering diagram?
The reson i ask is because when i start the car it run for about 3 sec and then stall,
if i keep the key to crank position when the engine start it stays running if i don't keep cranking it stall's sfter 3 sec,
power get shut down at fuel pump if not cranking.
any suggestion?
wondering if there was any factory alarm on those car beause there is a small red light flashing in car.
i've been using the car for 1 year now never had problem until battery died, only got 1 key and no remote for keyless
entry it's a basis standard car.
KarTuneMan
Platinum - Posts: 7,056
Posted: January 16, 2005 at 1:47 AM / IP Logged
You'de better check your wiring.....no bypass is needed.
KarTuneMan
Posted: January 16, 2005 at 1:49 AM / IP Logged
Sunday, July 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
