need tach wire on 2001 sentra
tek2005
Posted: January 16, 2005 at 3:54 PM / IP Logged
need location of tach wire on 2001 nissan sentra
mobileworks
Copper - Posts: 136
Posted: January 16, 2005 at 4:44 PM / IP Logged
Tech data didn't have anything but you can go to any injector and used the wire that changes color at each injector.
ex. Two wires to each injector....
1st injector     -One wire black one wire blue
2nd injector    -one wire black one wire green
3rd injector      -one wire black one wire tan
4th injector      -one wire black one wire yellow
Use the wire that changes color ......in the above example you would use blue green tan or yellow.
italnpimp59
Silver - Posts: 427
Posted: January 16, 2005 at 7:23 PM / IP Logged
dont go by that.  the way to find a tach wire is with your multimeter.  set  it to AC voltage, put the red in the positive battery post and the ground lead into the wire you want to test for your tach wire.  the voltage should go up and down when you rev up the engine. test every wire at the injectors and you will find one that reads correctly.
Craig3708
Copper - Posts: 155
Posted: January 16, 2005 at 7:51 PM / IP Logged
For tach go to any of the coils and use one of the following: BLACK/ red, purple, blue/red, or gray/red. Can also use blue/orange at the instrument cluster if vehicle is equipped with a tachometer.
Craig
Tuesday, February 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
