Plye pwd 103 lock/unlock
jayyzr
Copper - Posts: 114
Posted: January 18, 2005 at 9:37 AM / IP Logged
I have a plye pwd 103 Keyless entry w/ built in lock relays,Hooked it up on a 1992 Nissan Stanza. My question is with the wiring of the door locks would i connect the wires just like I was wiring up relays.. here is the wire diagram
Violet - unlock #87 Normally open input [10A fuse]
Blue/Black - Unlock #30 Common Output
BROWN / Black - Unlock #87a Normally Closed Output
Violet/Black - Lock #87 Normally Open Input [10A fuse]
GREEN/ Black - Lock #30 Common Output
WHITE/ Black - Lock #87a Normally Closed Output
The reason I ask is that the way they say to hook up a negative pulse system would be to
Hook Blue/Black(Unlock #30 Common Output) - to Door lock
BROWN / Black(Unlock #87a Normally Closed Output) - Door Unlock
Violet(unlock #87 Normally open input) - to Ground
Violet/Black(Lock #87 Normally Open Input) - To Ground
And dont use the GREEN/ black & WHITE/ black
it dosn't work in fact gives the unlock a ground at connection..
Taking It 1 Wire @ A Time...
jayyzr
Copper - Posts: 114
Posted: January 18, 2005 at 11:15 AM / IP Logged
Have anybody every used one of these pyle units
Monday, March 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
