Aftermarket Power Locks - Please HELP!!!
RBeach
Member - Posts: 11
Posted: January 18, 2005 at 10:26 PM / IP Logged
Hello all!
I am having s problem installing aftermarket power locks into a 1986 Ford F-150. It is a central locking system for 2 doors, with 2 5 wire actuators (made by Tesor). Everything was hooked exactly as instructions said (color for color). Nothing worked. I did as suggested in instructions and switched the brown and white wires on both actuators, and it will only unlock and not lock. I tried switching the blue and green wires but it didn't seem to cure the problem (only seemed to reverse action of one actuator). Any help would greatly be appreciated.
Rusty
Hymer
Silver - Posts: 695
Posted: January 18, 2005 at 10:43 PM / IP Logged
Your missing something simple... check your master switch connections and check the fuses (the ones that came with your kit...)     + and - on one side of the actuator will open (unlock) and reverse the connections for the other (lock)...
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
