1998 honda crv, 791xv
ksingh
Copper - Posts: 62
Posted: January 20, 2005 at 10:14 AM / IP Logged
I have a viper 791xv to install in a 1998 honda crv , now when I pulled up the vehicle info sheet on this site it says that you have must use RELAY's for the door unlock which is GREEN/ orange and also for the FACTORY DISARM which is yellow u must use a RELAY.  Now can anyone of you guys tell me what that is all about cause i have done alot of hondas and they all have the nevgative type doorlock and i never ran into this case where u have to use a relay for the doorlock and same goes for the disarm.  Also what do they mean by the factory disarm being THIS IS IGNITION FOR ALARM AND USE RELAY.  If anyone knowwhat that is about please send me an email
Kenny
italnpimp59
Silver - Posts: 427
Posted: January 20, 2005 at 10:56 AM / IP Logged
12volts white   +  ignition harness
Starter BLACK/ white   +  ignition harness
Second Starter
Ignition BLACK / YELLOW   +  ignition harness
Second Ignition
Third Ignition
Accessory yellow   +  ignition harness
Second Accessory WHITE/ black   +  ignition harness
Keysense
Power Lock GREEN / WHITE   -  driver door harness
Notes: Must use relays to trigger the lock and unlock wires.
Also found at the green factory alarm plug located in the drivers kick panel.
Power Unlock GREEN/ orange   -  driver door harness
Lock Motor WHITE/ red    drivers kick panel
Unlock Motor blue/red    drivers kick panel
Parking Lights+ RED / black    dash dimmer
Parking Lights- blue/red
Notes: This wire only works if there is a factory alarm installed. It is at the green factory alarm plug in the drivers kick.
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light GREEN/ black  +  driver kick, harness to rear
Door Trigger lt. GREEN/ red   -  drivers kick
Notes: Also found at the green factory alarm plug located in the drivers kick panel.
Dome Supervision comes on with unlock
Trunk/Hatch Pin blue/black   -  drivers kick
Hood Pin yellow/red or yellow   -  hood switch
Trunk/Hatch Release yellow   +  release switch
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer blue  AC  test connector
Notes: Found at the 2-pin tach test connector on the drivers side of the firewall.
Wait to start
Brake Wire GREEN / WHITE   +  cruise control
Notes: The cruise control module is located in the drivers kick panel.
Parking Brake
Horn Trigger gray   -  drivers kick
Notes: May also use blue/green at the steering column, negative trigger.
Memory Seat 1
Memory Seat 2
Memory Seat 3
1998 honda crv, 791xv -- posted image.
Immobilizer Bypass Module:Required: NoType: N/APart #: N/A
Notes: N/A
 i dont know what tech sheet you looked at but this one is from Directechs.  i have never done a honda where you had to use relays to trigger lock and unlock but who knows, this one might be different.  just to be  safe, i would use a relay cause it cant hurt anything to use one, but it CAN damage something if you dont use one when you should.  as far as factory disarm, dont worry about it.  even without lookin at this tech sheet i know that you wont have to worry about factory alarm on this vehicle.
