2003 Chrysler Town and Country
Ohmz
Copper - Posts: 193
Posted: October 25, 2002 at 10:22 AM / IP Logged
I need the wiring diagram for this vehicle. I am installing alarm/remote start. Any infomation on any extra equipment needed to do the remote start?
My Personal Installer Note: Connectors are easy, neat, and professional. But do you know how to crimp properly?
Big Dog
Gold - Posts: 1,265
Posted: October 25, 2002 at 2:38 PM / IP Logged
Hey Ohmz,
Here's info for T&C 2003.
|       ITEM                                |     WIRE COLOR              |POL|                    WIRE LOCATION        |
|              12V                           |lt blue/red (10A) *1           |+  |                         ignition harness            |
|          STARTER                    |yellow                                 |+  |                         ignition harness            |
|   SECOND STARTER         |PURPLE / brown *12             |-  |                          ignition harness            |
|         IGNITION                      |pink/white                          |+  |                         ignition harness            |
|        ACCESSORY                                                              |*11                                      |   |                            |
|       POWER LOCK               |PURPLE / green *3                |-  |                          conn. 3, pin 21 @ BCM *2    |
|     POWER UNLOCK           |same wire                         |   |                            |
|       LOCK MOTOR                |tan/white                            |   |                          conn. 2, pin 10 @ BCM *2    |
|     UNLOCK MOTOR           |tan/lt. green                        |   |                          conn. 2, pin 28 @ BCM *2    |
|    DISARM DEFEAT              |tan/brown                          |   |                          conn. 2, pin 26 @ BCM *2    |
| PARKING LIGHTS +            |DO NOT USE                    |   |                            |
| PARKING LIGHTS -             |WHITE/ brown *8                  |   |                       headlight switch            |
|       HEADLIGHTS                  |same wire                        |   |                            |
|     DOOR TRIGGER              |*4                                        |-  |                     BCM *2                      |
| DOME SUPERVISION         |use door trigger                |   |                            |
|  TRUNK/HATCH PIN           |PURPLE / orange *9              |-  |                     conn. 3, pin 29 @ BCM *2    |
|         HOOD PIN                    |PURPLE / lt. blue                     |-  |                    conn. 3, pin 30 @ BCM *2    |
|TRNK/HTCH RELEASE      |*10                                       |   |                     *10                         |
|  FCTRY ALARM ARM         |PURPLE / lt. blue                      |*5 |                    conn. 3, pin 14 @ BCM *2    |
|FCTRY ALRM DISARM       |same wire                            |   |                            |
|       TACHOMETER             |*6                                            |   |                    ignition coil pack          |
|      SPEED SENSE             |blue/orange                          |   |                    PCM *7                      |
|       BRAKE WIRE                |WHITE/ tan                               |+  |                   brake pedal switch          |
|     HORN TRIGGER            |GREEN/ purple                        |-  |                  steering column             |
|           WIPERS                     |brn/wht & brn/org                 |+  |                 wiper motor                 |
|  LF WINDOW UP/DN         |org/lt grn - org/wht                |A  |                drivers window switch       |
|  RF WINDOW UP/DN        |org/tan - org/gry                     |A  |                drivers kick panel          |
|  LR WINDOW UP/DN        |org/blu - org/lt blu                  |A  |                drivers kick panel          |
|  RR WINDOW UP/DN       |org/gry - org/grn                      |A  |                drivers kick panel          |
|        RADIO 12V                   |gray/red                                    |+  |radio                       |
|     RADIO GROUND            |                                                  |   |                            |
|     RADIO SWITCH              |blue/pink                                  |+  |                           radio                       |
| RADIO ILLUMINATE           |ORANGE / tan                               |+  |                          radio                       |
|       LF SPEAKER                 |green - grn/brn                        |   |                           radio                       |
|       RF SPEAKER                |gray - gray/brn                          |   |                         radio                       |
|       LR SPEAKER                 |grn/blu - grn/org                      |   |                         radio                       |
|       RR SPEAKER                |gry/blu - gry/org                        |   |                         radio                       |
Notes:
NOTE: Chrysler vehicles that use a gray ignition key have an immobilizer system that needs to be bypassed when remote starting. Use DEI part number 555C or 555U.
*1 This wire is rated at 10 amps only. If installing any system with high current outputs, go to battery for 12v.
*2 The BCM is in the drivers kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs.
*3 Lock is negative trigger thru a 5.3K ohm resistor. Unlock is negative trigger thru a 2.0K ohm resistor. MUST use relays.
*4 There are separate door triggers for each door, they are all in connector 3 at the BCM. The driver door trigger is purple in pin 6, the passenger door is PURPLE / white in pin 7, the left sliding door is PURPLE / gray in pin 8, and the right sliding door is purple / YELLOW in pin 5. Use all four and diode isolate each.
*5 Arm is negative trigger thru a 1.5K ohm resistor, this will also lock the doors. Disarm is negative trigger thru a 9.1K ohm resistor, if use double pulse this will also unlock the doors. MUST use relays.
*6 On the 2.4L use blue/green or blue/tan. On the 3.3L/3.8L use blue/green, blue/tan or blue/orange.
*7 The PCM is behind the driver side headlight. VSS is in the gray plug, pin 66.
 *8 The parking lights are negative trigger thru a 2.1K ohm resistor. The headlights are negative trigger thru a 790 ohm resistor. There is a rest resistance on the wire, so MUST use a relay to isolate away from the switch.
*9 A diode must be placed inline on this wire to avoid problems with the dome lights and parking lights.
*10 Hatch release is PURPLE / tan in connector 2, pin 6 at the BCM. It is negative trigger thru a 1.69K ohm resistor. Left power sliding door is PURPLE / blue in connector 3, pin 1 at the BCM. It is negative trigger thru a 1.5K ohm resistor. Right power sliding door is the same wire as the left and it is negative trigger thru a 2.7K ohm resistor. Must use relays.
*11 Accessory is not required for remote start.  *12 The second starter wire is negative trigger thru a 180 ohm resistor. MUST use relay.
2003 Chrysler Town and Country -- posted image.
Prepare your future. It wasn't the lack of stones that killed the stone age.
Monday, March 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
